  • Replies 60
would you like to elaborate?
or is that you're interesting comment for the night lol
Haha, just depends on the look of the car really. Aluminium usually looks better on most cars, especially older ones. But on some cars, like V35's for example, the poly looks better. IMO atleast.
ZXY got rejected and i was told it was a restricted plate because of ZX. It resembled a model of a car so it was restricted.
LOL, anything with a "Z" in it could be too by that theory....
Why can't they ban stupid shit like "VVVWVVV" instead lol....
Doubt you would have a problem with that...
I went with polycarb because it would look better with the kit I have, (going slimline on the front), but aluminium suits any skyline fine.
I have a 33 GTR as a weekend car, hence the GO GTR, I have a Z33 that the lil lady drives (sal sacrificed), hence the Z33, I have a STI which is my work car (sal sacrificed) with BNVS on it, my old boy is on the interested list with Nissan Australia for a 35 (once they take orders he will place one) hence the GTR R35 and once the v-spec is annnounced for sale, I will sell by 33, Z33 and STI and buy one, hence the 35 GTRV so I am not a bad boy at all, the BNVS one I am going to take off though and put QIKSILV3R which just arrived (it is silver and pretty quick) on it because I fear that BNVS (which was a gift) is going to give someone enough motivation to feck up the car....
anyone want to buy it, $500?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
