Hi guys,
I've been slowly buying parts to upgrade my car
I've got turbo (HKS GT2535), intercooler (Cooling Pro Stealth Series for R34), front pipe (JJR Bellmouth)
Is a cat from a R33/R34 bolt straight on? I'm looking at a magnaflow 3inch cat that has been flanged already and want to that it will bolt straight on
I'm going to custom the cat back (don't want a cannon tip and can't find what I want around)
the last bit is the suspension - this is proving to be a nightmare...I don't know that the group buy is still going...if it's not going - that what options should I go for (don't want coilovers - too much hassles and I have read the suspension thread and made even more confused :D )
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/234655-cat-convertor/
Yes, 34 and 33 cats use same flange pattern, bolt on.
Have you considered one of these ? Mine came with the flanges, bolted straight on, very happy with it.
http://www.metalcat.com.au/
http://www.skylinesaustralia.com/forums/me...mp;hl=catalytic
http://www.skylinesaustralia.com/forums/Me...mp;hl=catalytic
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4110848
I fitted a JJ Bellmouth and Hi Flow X Force Cat. Fitted perfectly on my S1, with a 3" Cat back, as supplied
Increase in power most noticeable and saving about 2l/100 in fuel.
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4111027
yeah I would love to get a metalcat but there are none around and I have spoken to some exhaust places around my place there is a massive back order for these...they recommended me to go mangaflow (that's my second choice) or to wait (which I can't)
If I can find a metalcat that I can get straight away then i'll buy one
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4111312
just get the x force metal cat. cheap and good. be sure to get the high flow one its worth it.
Thats the one I got from JJ. Also put in a new O2 sensor at the same time.
I just came op the mountain and the difference with the X Force and bellmouth is amazing.
Before it was like 3 grand plus and 4-5 psi to keep at 60kph, now it comes up at 2and a bit with no boost, so in effect the S1 now comes up in D and not 2nd, hence the better fuel consumption.
Also fitted a hi flow panel filter caus I have a cold air deflector.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4115336
I have had a HKS 2535 on an R33 and I tried 3 different exhaust combinations and let me tell you the 2535 is a great punchy turbo but it really needs to breath!!!
If you can gut the cat and you will never look back, it really does make a massive difference.
It also makes your rear bar turn black from the carbon deposits your exhaust puts out too. But who cares when you've got a Stagea that blows flames? :/
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4116522
Well I got a magnaflow cat. got it for $280. Now just gotta go to the exhaust place and get the cat-back made up. Xmetal - the reason I didn't get a X-Force 5 of my friends had their one collapse on them after 6 months.
I'm going to go custom as I don't like cannon exhasuts (personal choice) and can't find a aftermarket dual tip exhaust (or maybe I haven't looked hard enough).
I was thinking to go for a de-cat...but i guess i want to go for a sleeper look
https://www.sau.com.au/forums/topic/234655-cat-convertor/#findComment-4117060
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
