Ah there it is:D thats a pretty small wastegate, but with such a huge exhaust housing it would probably be fine, so where are you going to fit it on the stock manifold? Or are you going to set it up like Rob77?
With a turbine housing that big, it would probably be a really good idea to get a killer manifold and some cams in there or you probably wont start boosting till 4th gear:p its a bloody monster!
https://www.sau.com.au/forums/topic/23467-t04e-on-rb20det/#findComment-502670
Yeah i said to him you are gonna run into all sorts of dramas...but yeah he said he wants to use the standard manifold and different cams. It might be a good idea to mount the wastegate on the turbo. But i don't know what he had planned with regard to that. I'll have to find out.
Scott
https://www.sau.com.au/forums/topic/23467-t04e-on-rb20det/#findComment-502685
Guest MrEscortCosworth
why have such a huge turbo with such a crap manifold, get a tuned one and you will notice the difference, like running 21psi with stock manifold and then drop to 16psi with a tuned one is a big difference especially when u consider that 5 psi was going back onto the valves, u can run more timing and get more power with less boost. turbo looks great otherwise.
regards Anthony
https://www.sau.com.au/forums/topic/23467-t04e-on-rb20det/#findComment-502713
Dosent matter what manifold that turbo would not suit a rb20, mine is on the limit size wise and is only the smallest type to4e, it makes fullboost at 4300rpm so yours would be 5000+, not good with little of boost.
Also the turbo would be a tight fit in the engine bay bolted to the stock manifold, so check that as well.
What other mods has he done to the car, in a few months i will be selling my kit, trbo, manifold, wastegate, cooler, pipes, chipped computer, z32 afm, everything to get 230rwkw and 12sec qtr times, for a lot less than would cost to do new.
https://www.sau.com.au/forums/topic/23467-t04e-on-rb20det/#findComment-502777
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
