OK, the Dr is for sale,list as follows.
83 DR30RSX
FJ20et,Arias forged pidtons, Tomei cams/cam gears, 550cc injectors, balanced bottom end with equal balanced rods, brand new Exeddy 5 puck HD clutch, new genuine Nissan head gasket, Wolf 3dv4 with hand controller, Garret GT35 turbs with 330rwhp @ 16psi, car has run up to 355 @ 19psi.
Fj turbo 5 spd, R200 lsd, S14 4pot front brakes and coil over struts and king springs, standard rear discs with S13 rear struts/springs.
Standard original interior is in immaculate cond as is the rest of the car with a genuine 69,xxx kays on the clock.
Price: looking for around the $14500 mark.
Contact details: 0414922685 or [email protected]
Cheers, Vaughan
https://www.sau.com.au/forums/topic/234717-fs-dr30rsx/
Sorely tempted by this as a track machine but in WA...arrrgh :wave: !
Any pics for curiousity sake? :laugh:
cheers
83 DR30RSX
Cheers, Vaughan
https://www.sau.com.au/forums/topic/234717-fs-dr30rsx/#findComment-4114247
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
