ok so went to take my diff out to shim it up, but the bloody drain plug does not want to come out. have used a lot of leverage (maybe 1m) and still didnt budge. so just wondering what i can do from here. should i just take the housing off and just wait for the oil to piss out of the opening? or is there something else i can do?
https://www.sau.com.au/forums/topic/234733-siezed-drain-plug/
heat is your friend. get out the oxy torch if you have acess to one and heat up the area around the plug. also make sure you are using the right tool. a half inch drive is not quite right, they are a metric square drive. you can buy the proper square drive tool for them and it works much better. and once out you can replace it with a drain plug that has a bolt head on it.
also, make sure you can open the filler plug first. nothing worse than undoing the drain, then being unable to drive the car anyway cause the filler can't be opened. :)
you can also get the small cans of freeze spray (i assume liquid nitrogen in a can) to try and cool the plug. not sure how effective they are though as I've never tried one.
I've had some success by grinding a large punch to the shape of the insert and flogging the shit out of it with a 5 lb dumpy hammer then trying to undo it a la normal.
( I really dont grind the punch but just use the 1/2 inch socket extension)
Do this at your peril because chrome vanadium can shatter under impact
thanks for all the suggestions guys, ended up getting it free by basically just finding a stronger tool and pulling as hard as possible on the 1mtr long leverage, finally gave, my f**king god was that tight lol.
also, make sure you can open the filler plug first. nothing worse than undoing the drain, then being unable to drive the car anyway cause the filler can't be opened. :P
yeh mental blank, cant beleive i didnt do this haha, first rule of gearbox/diff oil changes and i completely forget :)
i might just use this thread for any other issues im bound to come across with the rest of the process, the centre is out and got a new one going in with the shim, just gave it a clean with petrol as it had been sitting around and collected some crap, just waiting for it to dry atm
Next time take a slightly dull edged cold chisel & ball pein hammer..bite into the exposed side of the plug at about 45 deg angle, and make a series of strikes to turn the plug to loosen it...works 100% of the time on anything..drain plugs, wheel lock nuts, rounded bolt heads, broken studs, steering lock bolts, rusted bolts..you name it . Impact power..just keep it legal :)
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
