Drift Practise @ Queensland Raceway
  • Replies 71
ill take your mrs for a slide if my car is ready and i dont have anyone else in the car =]
show her how the chicks do it lol!!
I certainly have no problems with that! Might even have to take me for a lap as well.
[edit] oh haha ur not even going now :( whys that? rb25 didnt fit :P
Edited by Housie
pffft no
it so fits.. its just a neo.. which has f**ked up every thing :)
you bitches might be seeing me out there yet!!
i really do hope i can make it.. i wanna be there for your bdayy =[ wont be able to go as hard though
will have to run heaps low boost!! but i just cant wait to get out there
stoopid stingy dyno owner losahs!! >.<
Edited by drift barbie
we tried sooo hard to get there *crying*
if the loom wasnt a problem i would have =[
im so sorry i missed your bday slide =[ i really did try my hardest!!
if you give me your account number n shit i can put in your 25 bucks i dont want you to think i ripped you off =[
ps happy birthday mate
this is for JEZ
btw
Bit of an ordinary night for me :) too many people out there as well for my liking. Every single farking time I was 1/2 way through a good run some tard would have spun up ahead and ruin it for me.
Still shitloads of fun :) and no drift damage!!!! yeeeew! Feel sorry for the white r33 that took a huge front end knock.
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
