Drift Practise @ Queensland Raceway
Bit of an ordinary night for me :( too many people out there as well for my liking. Every single farking time I was 1/2 way through a good run some tard would have spun up ahead and ruin it for me.
Still shitloads of fun :) and no drift damage!!!! yeeeew! Feel sorry for the white r33 that took a huge front end knock.
Arr gotta appologise Tom, im pretty sure i spun out in front of u once mate ;) I rekon it would be fair to say that almost every second run i did i had to backoff and dodge the traffic.
Noel raised a very good point! Fortnightly meets!!!!!!
It certainly was a mad house last night, :D . Waiting for those 3 cars to be pulled out of the kitty litter wasnt much fun either.
And real shame about the r33 as well, very hard luck!
oi tom, did ur 'mate' (wink wink nudge nudge) :P enjoy herself? i think i saw her filming with her phone camera lol.
Jason
  • Replies 71
Jason
LOL, I can hardly complain about people spinning out infront of me, I was all over the bloody place last night. I made an absolute ass of myself too. Left from the line for turn 3 Put it out right down the straight, then left, then right and lost it nearly into the wall lol. Only like 20m from the start lol.... SHAME
Which one??? tee hee hee :( I had 2 female 'friends' out with me last night. I think Noel can back me up on this saying theres a different one every month too. The blonde enjoyed herself. The chick your on about came out last time with me and said she was bored. She was even bored after like 3 laps in Noels car when he was out getting a lil sideways....! didn't think she'd come again but I guess I was wrong.
And yes fortnightly runs would be good, especially as Im the only drifter I know with a reliable car lol.
Edited by ToMMaH
awww bloody hell, just wrote out a big post and then lost it. :D
lol tom how can anyone be bored after a ride in a 500hp skyline. i dont think that girls a keeper haha.
me cars pretty reliable to. funny that! being rb25 aswell :)
...RB25FTW...
^^^lol and as per msn conversation it wont work :( shes probably just leading you on AHAHA
you never know i mite drag my rig out to the next one ;)
LOL, who knows but I'll be like "I think we should get an r33, so go buy this this this and this" then Ill put them all on my car tee hee hee :(
bout time ya slack prick.
I agree 100%, Josh hasn't been in so long I don't even think he remembers what drifting is.
And how the hell did my shit stiring not get you to make a funny comment about what I said noel... very dissapointed.
Just tell her to be ready next time. We'll see how farken bored she gets. :(
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
