Gday crew just wondering what people are running on their cars cat converter-wise i want a bit more flow/grumble in my exhaust think its still running a stock cat converter. how have people done about either a high flow cat or a de-cat pipe? anythin that will stuff up the O2 sensors? any recomendation?
any helps good help.
thanks crew
Dion
https://www.sau.com.au/forums/topic/234741-to-cat-or-not-to-cat/
  • Replies 44
I had a bad experience once with a supposed "high-flow" cat, and lost a fair bit of top end, however id love to see some back to back results of these modern style metal cats that i see a lot of users running. Currently running a Just Jap decat pipe. would recommend it if you want to go the decat option as its nice quality. Make sure youve got a good front pipe too.
Im using a metalcat brand cat converter and ive noticed no power losses at all. Ive got two front pipes; one with the cat and one without, but i cant tell the difference except for the stain i get on the rear bar without the cat. Im using 3.5 inch exhaust, 4in cat and flows 350kw without a drama.
thanks peeps helps a fair bit! will prob go the high flow a good name one to be on the safe side of both the law and performance.
yeah i wasn't too sure about the O2 sensors as i work for fords product development and we have pre and post cat sensors to check cat operation in the falcons and fpv's. shame
thanks again
Dion
But if you get pulled over by the rta, they can pick it, and all of the off the shelf "high quality"decat pipes are able to be picked by the cops. The only way to get around being picked by the cops is to have a pipe welded through the guts of a stock cat.
Not worth it, high flow $300.
Fine max $10,000 or something, on a rwkw cost benefit analysis, you would likely be paying something stupid like $2000 per kilowatt.
There are other mods out there that will give many more kw per $$$$
LOL at good quality decat pipe, its a piece of pipe with 2 flanges, what difference can there be in quality?
In answer to your question, obviously functional quality of a decat pipe wont vary much, but there are definite differences in quality of materials and fit and finish among many of these so called "bolt-in" pipes.
yeah if i was to do a de-cat then i would deffinitely get the shell of one welded over the pipe where i am in vic dont have any rta crew bootin round pickin up crew just cops, and i never been pulled over yet always waved through busses and stuff so i think i will be right.
If you want to pay the $ - there are cats available that will flow as much as you want to go.
I have a CES cat and make 581 rwhp - we dropped the cat on the dyno and picked up 7 extra whp.
I have used one of the cheaper cats on the market who claim to be the beex kneez - it melted the internals after 7 power runs.
Why are people only concerned about outright power? Sure it may have only picked up 7hp at the top but what about midrange? What about on/off/on again throttle response, fuel economy?
Doing a dyno test tels you sweet fa realy about the drivability differences between having and not having a cat.
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
