Modifications
Interior
Velo Bucket Racing Seats
Blue RPM 4-Point Harness
Autotechnica Steering Wheel with Boss Kit
Autoguage 5" Tacho and Shift Light
Trust Twin Pillar Mount Holder
Greddy Mechanical Boost Guage
Pivot 3in1 Speed Meter
G-Zone ECU Racing Chip
Aluiminium Pedal Extensions
Neons Behind Dash
Pioneer MP3 Head Unit
V-Net 4100 Amplifier
Kicker KX200 Amplifier
Pioneer Compression Horns
Clarion 15" Subwoofer
Uniden Scanner
1kg Fire Extinguisher
Exterior
R33 GTR Fibreglass Rear Wing
GTR Front Grille
GTR Bonnet
Custom Cut Stock Front Spoiler
Apexi 3" Muffer
3" Front Pipe
Custom 3" Exhaust
3" Cat Pipe
5 Puk Heavy Duty Clutch
Apexi Lowered Springs
Underbody Neon Car Kit
Grade 15 Window Tint
Short Shifter Kit
Under the Hood
Blitz Metal High Flow Air Filter
Custom Exhaust Manifold
Custom Intake Piping
Twin RB20 Turbos
NKG Iridium Spark Plugs
UAS 600x300x75 Front Mount Intercooler
Aluminium Mandrel Intercooler Piping
TurboSmart Dual Stage Boost Controller
GFB Mach 1 BOV
Cyclops Paralyser P350 Alarm System
Performance to date
13.7 @ 104mph 60' 2.28
~200bhp @ 13psi (1 Turbo)
https://www.sau.com.au/forums/topic/23475-all-my-mods-i-think/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
