Question: Flinders St/williams St. Speed Camera
Hey guys,
I'm very curious about something... the other night I was on my way to buy a HDD from someone and saw a flash as I went over a traffic light intersection, anyways, I thought I had gone over it as it turned red as I was looking all over for street names as I was not 100% sure where I should be going...
SO, I received a fine today, it's for the same place, but dated before I went out that night to get the HDD. It's for doing 60km/h in what I thought was a 60km/h zone, but it turns out it's 50km/h, and to be absolutely honest I thought it was a 60km/h zone and I can almost swear that I don't see any signage referring to speed limit leading up to that speed camera, but that could just be me, and I may need to take a drive up there to make sure, hence I'm asking here do I have any contest here? Or was I just retarded and not reading the signs 100% like I should, or is there a blanket speed limit for any city-like area?
More specifically, the location of the camera is here (Williams St/Flinders St).
Seeing as I have fine #2 certainly on it's way, that's 6 points - I have no idea about the demerit system as it's not really my intention to ever have deal with it, so how does this work? From what I know, there's a total of 12 maximum demerits, and after that it's license suspension? I obviously have hefty finage to now pay, which is shit enough. How long do demerits last for before they expire?
Thanks for your help, please no sarcasm or griefers, don't really need that right now. :P
hey dude .um well unfortunatly legaly they dont have to have speed sighns in everypart of a street just like every 600 meters or what ever so that cant be protested against which sux and the road rule is 50km in all built up areas ie ( near houses shoping centres,places where there is a lot of ppl unless otherwise marked..so its pretty hard to dodge the bullet.sorry bro
sooo.... they said you were there when you actually weren't? i don't quite understand.. if you can prove that their timing system is out that might help your cause a bit.. but yeah the general rule is 'if there's no sign it's 50'..
bad luck mate, i feel your pain..
Ric
Ric
Na dude, I was driving there a while ago before I got the HDD - but never saw the flash during day-time. I have even SEEN people get flashed here at night when I wasn't driving, I just assumed they were going faster than 60km/h :P. So the other fine is definitely coming. As far as I know I've driven by there a few times... so maybe I'm totally fu!ked.
50 in built up areas, blanket and much publicised etc etc. So you cant get away with it.
As for it being not when you thought - i doubt that.
however if you think its wrong go view the photo and you'll be able to see if its your car or not (details are on the back of the form i believe)
+1 - If there's a chance it's not you, go and buy a copy of the photo. A guy from back home got done for using (and speeding on) CityLink with no pass, and the rego on the fine was for his tractor. If the plate's obscured or slightly illegible, they just send it to the closest match.
Otherwise, as said - If it's unsigned, it's 50. So i don't think you've got anywhere to go on that one. And you're tagged with the points for three years.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
