zerotohundred,
Pretty sure it's 400R bumper (can't tell if it's plastic or fibreglass - owner can confirm) with Series 3 GT-R front lip.
Cheers
Grant
Yusss ;) Another peep with that seemingly uber uncommon front bar!
Wish mine was purple tho.. always wanted one that colour!
As people have mentioned.. say goodbye to your wallet! Burn those CC's now! I bought my exhaust 4 months before i even owned a Skyline ;)
Spent a sheeetload since too... but its all worth it. Love it to death. Bar the colour we have the same kit overall too.
woot! action shot :)
this is my 98 40th anniversary. with a list of mods that runs for a page long. wouldnt sell it for anything else though.
I loved it until i spotted that giant wing on the back.
What have you done to it. NNNNNNNNOOOOOOOOOOOO!!!!!!!!!
lol GT wing has since been removed and replaced with a D Wing :P i know. it came over from japan with the wing on it. just never got round to removing it.
Front bar looks 400R except the bottom lip is different, looks like an aftermarket lip or one that has been modified.
it is exactly the same as this front bumper here.
The standard 400r front bumper you see on most gts-t isn't an original copy the lip is shaped differently.
This front bumper on this GTR is a genuine 400r front bar and same one that is on my gts-t. i still havent seen this front bumper on any other gts-t in the world.
Great purchase mate! Midnite purple is a top colour.
So good-bye to all your hard earned though!
Seeing as you have an auto there's someone on this forum who has a you-tube vid of there customised auto shift kit in action.
It's absolutly wicked. I'll try and search for it and pop it up as an idea for you instead of converting to manual as that'll be big dollars.
Cheers and good luck!
  • 2 months later...
  • 3 weeks later...
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
