Hi guys, before i go checking every hose etc on the car. i was wondering if anyone has had this problem and knows off the top if their head how to fix it?
1990 r32 gtr, standard ecu. this car has for some reason decided to idle at 1100rpm for a few weeks now. stil runs smooth and nothing has been touched in the engine bay. it also feels a bit underpowered to me. any ideas?
https://www.sau.com.au/forums/topic/234785-r32-gtr-high-idle-1100rpm/
i know that my manual that i had but lost said that normal idle is 950rpm ish and that i have a nice split turbo outlet pipe and leaks like a mofo so i am at 1100 rpm at my idle now. so yeah just confirming to have a look for that leak.
good luck. good trick try real soapy water arround hose clamps and joins and see if it bubbles.
enjoy
Cheers guys. im gonna chuck a boost gauge on tomorrow n hopefully that tells a tale. i had a similar thing happen on a mitsi gto that turned out to be a leaking hose under the inlet manifold on the old twin turbo v6. i imagine its the same deal here. Are there any hoses other than turbo outlet that are known more than others to leak?
I too have been trying to fight the evil high idle. I have at least stopped it hunting by looking at the guides for cleaning the AAC valve and have recently diagnosed that my idel switch in the TPS doesnt work (I think that anyway). I am sure that I am getting air in maybe near the inlet manifold so Ray at RE Customs said try spraying brake cleaner around. If teh engine changes pitch then the brake cleaner is being taken in and burnt. I am not sure if this will work around the rest of the pressurised system.
Anyway keep us posted on any eventualities
My car used to allways idle around 1200 and now just hunts for idle all the time. engine temp doesn't make difference.
Think I will do the AAC valve first as people seem to have good results. How do I check the Idle switch on the TPS?
Thanks for any assistance.
My car idles at 1600rpm and no obvious boost leaks either. Been like that for a very long time. I don't think i'll get it sorted until i do a rebuild and go over absolutely everything. Car still runs fine and has no other issue.
the 6 throttles that bolt to the head have like a clear coating around them internally where the butterfly's close, if any type of cleaning agent is used inside, say like a system cleaner or carby cleaner, it can eat away at the coating causing the butterfly's never to seal properly again, never spray anything in there...
make sure the idle screw is screwed in, if its all the way in and it idles high, ^^^ is your problem... not fixable on the cheap side and its a off job to do so..
hello again. i put a boost gauge on the car today and it is running between 11-14psi. seems like 12psi most of the time, the car usually runs just over and holds 14psi when it was running correctly. now i've checked hoses etc and all seem to be ok. the two running off the boost solenoid look at bit old but they have always and never caused a problem in the past.
BUT...on further investigation i have found that the injectors on 4th and 5th cylinder appear to be leaking from where they connect to the fuel rail. is this what is causing my high idle possibly?
the car is going on the dyno at created performance next week to see what the hell is goin on with high idle and slight lack of power, but i would like to figure it out before i take it there.....not to avoid cost of checking/repairing, more so i can see what shes really got at the wheels knowing that its running correctly! :laugh:
THANKS FOR YOUR HELP SO FAR GUYS!
Yup, I got told this too by my mechanic. He was able to adjust the idle down with the Power FC. Still about 1000 at idle. Said it's a real fiddle to fix.
I had the same problem with high idle, about 1100rpm. I thought it was normal until I looked on the inside of the bonnet one day and I think it said idle should be 950rpm or there abouts.
I got my Vipec V88 installed and my tuner spent a lot of time getting the idle right (as his dyno was getting fixed he had about 3-4 days to do it). Now is sits on about 700rpm and seriously it sounds sweet and never skips a beat.
High idle was with the standard computer by the way.
Mike
ahhh nobody has mentioned that to me ever but it makes perfect sense. That could definatley be the culprit. Oh well i'm not really to fussed about it for now as long as it won't damage anything. I'll wait for a rebuild or new motor me thinks before i do anything about it.
How hard is it to take the plenum off to fix this though. Could i do it in a day??? just incase i get bored one weekend. car is off the road anyway for an undetermined amount of time anyway for other reasons.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
