Hi all,
I am new to this forum and just wanted to take this opportunity to say Hi and ask few questions while I'm at it.
I've been on a holiday to Japan couple of months ago for the first time and I just fell in love with that country and with their automotives.
I had pleasure of driving Nissan Skyline Sedan rent car from Nissan Rental (pretty obvious).
Now that I am back to Good old Sydney, I was wondering if I could import that car.
I am catching up with readings on this forum for enlightenment on art of importing car as I have never done this before.
But I honestly need some guidence from the Master Importers.
My Question is
1. Is V36 - 350GT allowed into the country yet?
I've searched SEV list and found:
509/00 MA Nissan Skyline V36 10/2006 Current
VQ35HR 3.5ltr 232kW V6 Engine – 145kW/tonne - YES
Does this mean it is allowed to be imported?
2. Compliance (RAW)
Is there any work shop who is eligible to carry on the compliance work for V36 - 350GT yet?
And if there is, what is the cost please?
3. Parts for VQ35HR
Is parts for V36 - 350GT compatible with V35 or 350Z Fairlady?
4. 350GT Type-SP
I was wondering if all the Sat-Nav and Menu can be "Fixed" to Australian or English setting.
I was told 350GT is a HDD Satnav and not a DVD one so I can update the maps using SD Card but will I be able to load it up with any version of Australian GPS Map?
5. Price
How much will I be looking at to import this car?
I was told on price guide as 2,500,000 - 2,800,000 Yen for 06' model
I'll look forward to hearing from you.
Cheers,
DY
Edited by annexe
https://www.sau.com.au/forums/topic/234788-v36-350gt-2wd-sedan/
Q1 & 2... sample cars are already in but there may not be any RAWS that has a compliance plate yet.
So price for compliance is unsure at the moment. The V35 compliance on average cost $3k plus tyres.
Q3 & 4 - no. all screen in japanese fixed. fullstop. may take time for local electronic experts to find a way to tap in the video signal and piggy back some english navi unit / tv tuner into the screen display, but that's about it.
engine part I believe would be different. some would be shared.
Q5. there's a import calculator you can use from j-spec.com.au or prestigemotorsport.com.au
just factor in about $1k+ for shipping, about 15% import duty, and 10% GST, and compliance cost plus tyres.
Then the rego cost in your state.
Thank you rs73 for detailed information.
I certainly appreciate your insightful knowledge.
Certainly is a expensive exercise to import a car....
This has already being covered before
http://www.skylinesaustralia.com/forums/Ni...7s-t232962.html a review on the V36 AKA as G37 the Infinity brand in the States. Pretty interesting on what they had to say.
http://www.skylinesaustralia.com/forums/V3...gt-t192638.html Compliance when it will be available.
Thanks for that MFC05,
Haha technology is wonderful thing isn't it? maybe I should learn to use the latest invention called "Search"
Well I'll just have to stay tunned to see what will happens to the V36 then.
Happy motoring :D
Edited by annexe
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
