Hmm, Ok in the last post though someone suggested using a plasti guage to do this and then someone else said that was a stupid idea and doesn't work.
What is the best way to ensure the clearance is perfect?
Thanks for your help guys
You really need to use a outside micrometer and bore gauge (correct term???? )
the one in the bore looks like a telescopic gauge?
I prefer to get a dial bore inducator, that can go from you main and big end size all the way to you piston bore. I then use an outside mic on the crank.
Now I put the motor back together all to spec and torque, I ran in the new rings with run in motor oil and all was well the car was driving fine... and FAST!
So when you say clearences what do you mean? suddenly I am feeling a little sheepish.
Wait, you're driving FAST while on a run in, and you don't know what clearences are, but you're trying to build your own motor?
My god man, take it to a workshop before it happens again!
Did you even get the crank machined to suit the bearings???
I prefer to get a dial bore indicator, that can go from you main and big end size all the way to you piston bore. I then use an outside mic on the crank.
thats ^^^ the one :( (dial bore indicator) i forgot the term :D
haha don't mind my spelling, i think im the first university educated engineer with the spelling skills at a grade 6 student lol
on a side not i tried to edit that last post and the edit button has vanished, but is on this post??
Edited by GTR1993
No no no, I wasnt driving fast during run in, I did the complete run in cycle, 5000 k's of labouring and babying and so on, with correct fluids, then 500 K's on new redline oils, then oil change again to make sure all was well and THEN the problem came up.
the one in the bore is simply an inside micrometer.
But mostly just skids, right?
This is why when I need an engine built, I go to.....drum roll......an engine builder. Just the same as when I need a tooth pulled I go to the dentist.
Sif man....Dentists build sick engines.
Well I could go to an engine builder and throw more money at it, true... Or I could learn the lesson here about what went wrong so I wont do it again, and when the car is back up and going I will have learned something and built something.
I don't see the point in having someone else make it for me, it's half the fun and later on I might like to do a bigger project my self... it's better I learn on this motor than one that will cost a fortune.
all sarcasm aside, I appreciate all the help and suggestions guys.
I have ordered the new rods, bearings and so on, I WILL take it all to a machinest to make sure it will all match perfectly, then I will throw it all together...
more on this to come I suppose.
So you're having fun?
I prefer a bottle of scotch and a hooker but each to their own.
I believe I made the suggestion and listed all the parts (measuring equipment) you will need to get the job done properly. It's back in the other thread....which is now this one.
yeah your mistake was re-assembling it with factory bearings after having previous issues, I would say the crank was still bad when you re-assembled it. As mentioned by someone else already factory bearings will be OK as long as the crank has not sustained any damage, and I would say the clearances are out on whatever number it lost.
Pull it down again and take it to a machine shop/engine builder. Get them to check the crank/block/cradle and fit aftermarket bearings to suit the crank, depending on if they can polish it out or whatever. I myself would probably source another crank but and still take it to a machine shop to be checked.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
