29 psi with meth injection 160 kilo driver with hooser drag slicks :banana:
here is a sumary of the event my races are at 1:50 2:50 7:43 http://videos.streetfire.net/video/4ta-Fec...o-de_180087.htm
Edited by ReganGTS25T
https://www.sau.com.au/forums/topic/234848-ran-an-111-et134-on-pump-gas/
Whats the cars mods how much power???
cp pistons, tomei rods, port n polish, greddy intake manifold, q45 tb, haltech ecu, snow perofmrance meth inejction kit, gt3582r .82 ar ebay reinforced header, sard 850cc injectors, thats biscally it for power mods, at 29 psi 630 crank hp on pump gas, basically your same setup but with the full gt3582r meth injection and a built engine at 8.4:1 comp
You cannot claim 134 MPH if they don't record it on your run mate :3some:
Well done, the water meth made a big difference for you. Might switch mine on soon :D
I see you get wheelspin, that helps heaps. i just bogged
Your 60ft?
What size tires you have?
Put in the rear your stock suspesion!!
no 60 foot times sorry they are 26x9 15 hoosier drag slicks and i dont have stock suspension car came with the hypermax's, but i dont think my 60 foot time is all that good to be honest, i dont got launch control so i cant leave on boost so i have to compensate that by launching at a high rpm so i dont bog and 2nd gear gets little traction also, gota remember its not a preped track its an ultra light air strip but its all we got down here im just happy to be kicking some v8 ass
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
