Hi,
I got a problem with my lights, when i turn on the low beams they work fine but when i then switch to high beam the low beams turn off and high beams come on. And this should not happen, both the low beam and the high beams should be on when u turn on highbeams? I only found this out when i went to get a pink slip and they wouldnt pass me cause of this....I tried to make it out that Japanese imports do this kind of stuff lol but that story didnt work...
Could this be a problem with the light switch?
Any help would be appreciated.
by the way the car is a R33 S2.
https://www.sau.com.au/forums/topic/234873-problem-with-lights/
This is standard on ALL R33 Skylines - you only have two lights on at any time.
It is not a legal requirement that you have four lights on when high beam is on and if they try to tell you differently then go to another garage that knows their stuff.
Far out, i payed the guy $150 deposit to say that i would book a visit for him to fix it... thats the only way he would let me pass pink slip... How can I prove to him that ALL skylines do this, or some kind of regulation that says u dont need 4 lights on when high beaming.
Thanks for the replies fellas
Ah how bout the fact that people have melted the headlights from running highs and lows at the same time. Then NONE of the lights will work...
And 150 is crap. Do you get that money back if you take the car to him, cos 150 is way too much to wire ur headlights up like he has said. Takes all of 5 mins..
I'll go back to him and ask for my money, but he seems to think that all cars need to have all 4 lights on when highbeaming, as in both lowbeam and highbeam on at the same time. On the pinkslip he failed me on rule 106.02 - "Headlight (high/low beam) now working or damaged"
Hmm. Im not sure exactly of that rule but i know for a fact that there are a lot of cars out there that do not and never have run low beams AND highbeams at the same time. Wats your mechanic like? I have met some who will fail you on anything they can just to make some more money out of you.
Pull the globe from the low-beam mounting, and show the twit that there is only ONE filament.
No car I am aware of, where the lamp has a twin filament, ever has the low-beam filament active once the switch activates hi-beam.
And if it is a problem, how on earth did the car pass compliance in the first place?
Anyone got the wiring diagram for a Skyline. I think any Skyline would do, because my 32 behaves like that - and I've NEVER had a problem with RWCs (pink slips).
I'm pretty sure i compared this with my friend's 200sx s14, and when he highbeamed both the highbeams and lowbeams were on, and that is a australian delivered car, i could be wrong though... Also good point if all skylines are like this how could they be complied... anyways does anyone have a wiring diagram for skylines??
Edited by da spike
I dont usually go to this guy but it was a last minute pink slip as rego was expiring the next day, but hes very picky about everything, he also wanted to fail me on wiper blades rubbers being split but they werent actually.
This guy sounds like he has no idea.
Take it back and tell him to get his fax right!
I took it back and called the RTA to confirm that both low beams and high beams do not need to be on, the guy in the RTA didnt know much but said that its fine...
So i got my money back and my pink slip :)
Edited by da spike
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
