  • Replies 54
atleast 20,000 kms on 100 octane (the purple pump) from united on princess hwy near springvale,police rd making just under 300kws tuned on 100octane no probs what so ever....filled up last wenesday at $1.12 a litre
in my opinion....
i have used both united plus and v-power. whether its psychological or actual gains i believe in my opinion the v-power was a much better fuel for my car based on daily driving performance and kilometres per tank.
vehicle: r34 GTT sedan. completely stock no engine mods or exhaust.
fuel period used: 1 month on each.
route taken: same route 7days a week to work and back.
result:
the exact same route was taken each day. i did my best to drive it consistently for the 2 month test period. no flooring or burning people off at the lights mostly freeway driving with the occasional squirt.
the result i got was 455km out of a tank filled consistently each time at 51 litres using united plus fuel.
whereas
the v-power gave me 475km out of a tank filled consistently each time at 51 litres.
Not much difference in terms of km outcome however i did notice when using united plus petrol it did run a little more rough. cold starts were not as smooth as when i ran with v-power. when i did give it a little squirt it wasnt as smooth as v-power. v-power just seemed more suited to my car. the engine seemed more responsive and quieter and not as hesitent. Overall a much better fuel in my opinion.
In conclusion i would have to say, if you can afford to drive a turbo car or any type of sports car, the last thing you should be complaining about is fuel. Dont be a tightass over a couple of dollars because at the end of the day if all fuels were priced the same i gurantee everyone would be using "reputable" brand fuels.
cheers everyone
Edited by humsup34
Was there any difference in power between the tunes? Have you filled up with 98 since when 100 wasn't available?
there was considrable difference between 98 and 100 fuels when i had mine tuned, at racepace, more power thru the whole rev range.
i have used 98 a couple of times when 100 was not available but i stayed away from boost and did not load the engine.
Ive recently been using the united 100 as my car has been tuned for 100. Its great, knock levels are actually better on the same tune. Dont care about ecconomy at all, just knock and power.
I'm now testnig a E85 blend and slowly adding in more timing to the tune..e85 is the shit, havnt done a dyno but knock is staying ok with a few more degreess accross the map everywhere. ethanol is great! just dont spill it on ur paint..
went to fill up on 100 today on princes hwy, they were out..
they always seem to be out of 100 octane on princess hwy but i guess taht just means that there stock just rotates and they dont have old fuel
  • 1 year later...
  • 4 weeks later...
DuFFR32, that is not entirely correct. The higher the octane[ RON] the less chance of knocking and pinging. RON is the fuels ability to resist knocking not volitility . Higher RON lets the ecu feed in more timing for more power until the knock sensor hears the knock or approach and reduces the timing back to safe levels.
well thats just your opinion..
it could not be souly responsible for it, there are other factors that may have obviously contributed. All i am saying is i dont believe its wise to be running this fuel consistently in a NA. Why not just run it on normal unleaded and you will have no drama's
Well it's my opinion too. Most modern cars are quite capable of running ethanol, whereas older cars can be totally stuffed up. I don't know where the cut-off is, it probably varies by model, but I wouldn't even think of putting ethanol in, say, a pre-1990 car. Generally I'd say if your car was built before ethanol became widely used, don't do it.
I would never put ethanol in my car anyway unless it's specifically designed for it, but I'm prejudiced ;-)
I've said it before and I'll say it again in yet another thread about United Fuel.
My GF's Datsun 1200 has run exclusively on Plus ULP (95) octane for at least the last two years. All the fuel system, carburettor etc are fine, and this is in a motor dating from 1973!
I run the Boost 98 in my car when I have to, the only difference is that it seems to use more of it than normal 98 octane.
My old VN wouldn't start properly on United fuel (yes I did test this by running the tank down and filling up from a normal servo and United). I can't explain this phenomena.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
