Guys, FYI, I tried to have my ARX tuned last week but ended up with no changes.
The car is running quite rich with a 10:1 ratio across the rev range. No wonder she is giving lousy fuel consumption. Attempting to install an Apexi Super AFC Neo failed to improve the performance with the car's computer fighting the Apexi and causing a huge slump in mid range performance. It appears that no one has got the AFC working with the VQ25DET yet.
We are now looking for other options.
Has anyone sucessfully installed an emanage ultimate on these cars?
We also looked at increasing the boost slightly.
Interestingly, a standard car with a good air filter, high flow cat and muffler, she is already boosting at 15 PSI from low revs to mid range. I do not feel comfortable increasing beyond this point.
Drops back to 10PSI in the mid to upper rev range. I think that this is what is causing the unusual performance feel. Takes of reasonably well, but does not provide the rush as the revs increase.
Currently 150 KW at the wheels with a very flat power curve.
Any suggestions?
My thinking is to fix the fuel ratio and see what happens to the boost.
https://www.sau.com.au/forums/topic/234949-m35-tuning-observations/
Sydney Kid posted his experience fitting a Jaycar kit of Digital Fuel Adjuster + an Electronic Boost Control on his C34 Stagea. The results seem very good and were fitted very easily with just 6 wires needing to be connected.
Have a read of the thread as this is the direction I am looking to go to improve fuel economy.
Cheers
Andy
Haltec are working with the 2004 - 2007 M35's at the moment with the NA 3.5lt. I am also going with them in the next month or so with my car so I will have some results then.....as for the boost I am not game to raise it from standard until it dies.... also I am pretty sure a with a good muck around with the fuel mixtures and timing you should be able to get a good power increase from the Haltec system.
I do believe that there is a company in Sydney which have (and recommend) using the Haltec 350z Platinum as a piggyback for the m35.
The guy I spoke to said that they raised power and the owner is very happy with the new fuel consumption :)
Unfortunately, he did not tell me the numbers that were achieved.
The down side is that the 350z Platinum is a $2000 unit and he quoted me $3500 for the install & tune :) .
Not only that but my car would have had to be shipped as well *OUCH*
I will be going with the Emanage Ulimate soon and will share results when I have them, but would be VERY interested to see your results (if memory serves, a 3" turbo back & a boost controller, yes?).
$3,500? Nah!......I have been talking to them at around $1,200 then Dyno? I'll go and double check what I have been told and post a confirmed price estimate. No way I will be paying $3,500 for a piggyback!
$3,500? Yep! The 350z Platinum is a replacement ECU for (obviously) the 350z. It needs to be used as a piggyback for the m35 to keep the popup screen among other things.
They said that the Interceptor and the E11v2 cannot be used on the m35 for whatever reason.
This is from the email when I was still searching for an exhaust and ECU install.
"Ok, Transport can be between $400 and $500 each way.
Front pipe $500 with cat in 2 1/2 inch, 3 inch with High flow metal cat $800, am waiting on a price for the exhaust, no charge to fit it.
ECU fitted, wired and tuned $3500.
The High flow turbo on the stagea renderers it a little lagy, we can tune around it to some degree but we can run as much boost as you like depending on the results you would like"
Maybe it is just because I am not local... Who knows?
I would be interested to know which ECU they are fitting for $1200. As well as the results you get.
This might give the same results as the Apexi AFC Neo - they both work off the same principle.
I'm wondering if the problem is the side-effects in advanced ignition timing caused by the AFC?
If you can get hold of an SITC then give that a shot (no longer being made - basically does for ignition timing what the AFC does for airflow reading).
Also with boost that high, I'm wondering if that is the reason it runs so rich? From my experience, it tends to run very rich once you increase boost. Most people told me it would run lean (ie. thinking more air = lean) but I think what happens is that the computer senses the increased boost and dumps loads of fuel into the mix to try to protect the engine. So what you end up with is very low AFR's and less performance and increased fuel consumption.
Have you tried getting a cheap boost controller (try a turbotech one - they worked well on the C34's) and lowering the boost a bit? Wondering if that would make the tuning more predictable since it sounds like you're trying to diagnose several things at once there. Limiting boost to 10psi across the board would at least eliminate that from the equation...allowing you to focus on just tuning AFR's / ignition timing.
The unit I am told will work(from a mate at Haltec) is about $700 then you need dyno and install...it's also a piggyback and can only control booste, fuel, timing and o2. The thing that they really need is a workshop manual or the wiring diagram for the M35 with the VQ25DET.
I have the wiring diagram for the G35 that is very close to the M35.
What do you want to know?
Cheers
Andy
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
