Not sure if this is the right place to post this thread.. (feel free to move it)
I've just had my motor rebuilt and I need to put some k's on it.
How would I go about doing this? as the car is not registered (being a track only car)
Would it be best to do it on the dyno? Jack the rear wheels up in the garage and drive stationary? (neighbours would love that! haha)
What have you guys done in the past?
Thanks in advance
Liam.
90% of your running in is done in the first 15mins after start up. you should have held engine at 2500-3000rpm for 10-15mins. this runs the cams in as well as beds the rings. some load on the dyno will also do it the world of good for 15-20mins, then tune it. not a great believer of running in engines as the first 15 mins are critical. if the rings dont bed in then, they never will.
i will be firing my engine and running the cams in while i bleed the cooling system, checking it for leaks, then tuning it.
Dont jack the wheels up as that would not give the engine any load and it wouldnt run in at all...
Dyno is the only real option, or you can try geting a movement permit for it and drive arround for a while
Agree with above^^ Run it in on the dyno, tune it up and off you go. Should take 15-20mins and then usual time for tuning etc
And off you go, both my RB25 and RB26 were done that way. I even was off to the drags the next day with the 25 :P
Rest of the work is done @ the track.
Just remembered that my unregistered vehicle permit dosnt expire until next wednesday lol
So I guess I'll do a few hundred k's tomorrow.
Also when it was first started for the first time it was driven around the block a few times etc
Thanks for your responses anyway
Liam. :P
This Must Be One of those new DOHC rotarys I keep hearing about...:P
:P:P:P
What he said!!!
I'll have to bed in and run in my car too when I'm finished. Someone mentioned disconnecting the wastegate actuator arms to aid in bedding in rings (piston rings for me, apex seals for you).
lol I dont think i need to run in the cams as I dont really have any..
but I do understand what your trying to say.
Cheers mate
Liam.
Just run it in on the dyno mate, that's what I'll be doing.
What does your engine builder recommend?
I spoke with the engine builder and he said that the dyno should be ok to finish the job as I have already done just over 200kms on the street.
so all is good, just have to find the time and cash to get it on there now haha
but back to your first question....I'm a firm beleiver in dyno for 3 reason
1/ you don't really get all that much track time on a day, even with an open track day at wakie
2/ dyno can load the car up properly and you can run set it to the rev and load levels you want
3/ its much easier to pick and stop if something goes wrong. like your radiator being a little shorter than the standard one, coming loose, hitting the fan and cooking your brand new motor. for example.
and number 4 reason:
4/ since on the dyno you are not actually driving, you can focus all your attention on the gauges, AFR, revs, dyno load and tuning and not worry about hitting people, cars, trees etc.
5/ on the dyno you can legally and easily drive to any speed you want, so it's a simple matter to load it up in 4th and 5th gears which is impossible on the road without breaking any laws and difficult on the track as duncan mentioned.
I am currently running in my 13BT as well. :P in an FD though (2001 RZ model). you can see some pics of the build here if you're interested. I had it built at Pre-stage in japan, small but excellent japanese rotary tuner.
http://photos.yahoo.co.jp/ph/cyoko810/lst?...rc=ph%26.view=t
http://www.prestage.rgr.jp/workscar.html
PS, I do believe anyone within a 3 block radius of my place is now slightly hearing impaired... :P
I am currently running in my 13BT as well. :) in an FD though (2001 RZ model). you can see some pics of the build here if you're interested. I had it built at Pre-stage in japan, small but excellent japanese rotary tuner.
Haha they are loud bastards arnt they!
Pics look sweet as mate, are they brand new housings your using :P
How nice is that fc! I have heard of Pre-stage I actually used to have a pre-stage sticker on my fan shroud exactly where they have it in this link haha (purple to) http://www.prestage.rgr.jp/making/w990701.html
Do you have anymore pics of you fd?
cheers mate
Liam.
cheers guys, yeah I love it. :) The RZ version is a little special too, just 175 RZs' made it's the rarest FD RX-7 you can get. It comes with carbon kevlar recaros, BBS wheels, Bilstein shocks, updated interior, no rear seats, alloy foot panels, alloy bonnet etc. It's the lightest FD variant too.
Yep, brand new housings, they advised it was the best way to go and I didn't want to do it by halves. :P They did an awesome job with the build and kindly took lots of pics. I love the rotors but they just don't last. This car is a 2001 model with very few kms and no mods apart from the exhaust when I bought it, but it was already due for a freshen up!
I don't have any nice pics really, but here are some I took on the day it arrived in aus. very dirty!
Nice Richard!
I'm curious to see how well you fit in it? From memory you're not short!
I was chasing an SP for a while and gave up. I sat in a few and it was a tight squeeze with the sun roof that's for sure.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
