Steven Jones Nissan Skyline R35 Gtr Is The New Leader Of Quit Targa West Competition Modern Class.
Guest
 Share
Well done to Steve and Fabcar for there achievement at Targawest.
I know Steve is well known and has many freinds within the "grass roots" car enthusiast community in Perth, so to you eastern states guys, they are not only sharing an achievement, but just supporting and promoting a freind.
I was lucky enough to watch Targa West Last year while I was working over in WA and I watched Steve compete in his Lancer Evolution, and he was Damnn quick on some of the stages.
In support of Snowmans comments, I have driven on the targa west roads and taken a good look at them, and I know some of us here in Victoria would not even consider those roads a "hills run" - they are very fast and flowing and not very steep.
Before you WA guys jump up and down about gooseberry hill - I have mates whos driveways to there properties are longer and more challenging than gooseberry hill.
When you have events like Lake mountain sprint, Targa Tas and Mt buller, not only are the roads very different, in terms of surface and elevation, but the climate and weather conditions are different.
What I guess he is trying to say is, lets see how Steve will do in Events like these before getting all worked up.
  • Replies 64
Posted Images
The only person who can make some of these comments about Steve and his driving or why he won is the F@#KER who was in front of him at the end of the race..............no wait he came first.
If you cant make a comment that isn't derogative or in some way making a statement as to why he would not win some were else JUST GO AND GET A F#@KING LIFE...........
This topic was not started so the rocket scientists from the IT section can make one of their assumption statements, the kid won the race in honour of his fathers death so keep it to your self.
No this is not because I am living WA, it is because a few oxygen thieves need to think before they open their mouth.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
