Hi guys,
My housemate lost her garage remote control and we have to change the codes and re-tune the new controller.. anyone have any idea? I tried google-ing for manuals but just couldnt find the right one..
The garage door that i have is a
Gliderol (Glidermatic GTS)
Opened up the panel, and all i see is a switchboard with so many buttons..
At my old house, the garage had a reset/learn button which was there without having to even remove the panel..
Any help will be deeply appreciated.
Cheers,
Bernard
https://www.sau.com.au/forums/topic/235024-garage-door/
The ones my mate has is that you Press one button, then one remote and it locks into that memory, exmaple
Press the buttone (1) on the Garage door thing. then press the button on remote (1) straight after.
should work like that.
https://www.sau.com.au/forums/topic/235024-garage-door/#findComment-4116492
Gliderol (from my manual)
1. Press the LEARN code key once (on mine its the PCB-mounted push button on the main circuit board near the RF-reciever stuff)
2. the LEARN LED indicator will light up
3. Press the hand transmitter key that will operate the door (ie, Key 1 on the remote, the main button)
3. The learn LED light will go out.
Rinse and repeat for further new transmitters :/
https://www.sau.com.au/forums/topic/235024-garage-door/#findComment-4116515
I'll definitely try that out :P but is it possible for me to change the codes to a new one? just don't wanna risk the stolen controller being able to operate the garage..
https://www.sau.com.au/forums/topic/235024-garage-door/#findComment-4116572
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
