- R32 20mm wider front fiberglass guards one brand new, other has holes where was test fitted but not cut or anything - $150 ono
- Splitfire D1 ignition system ( its an earthing kit for coilpacks) cant use cause i want my coilpack cover on - $50
- r32 4 door taillights in gc - $80
- GAB shocks, rears damper adjustable and front shave lower springs
(not sure on condition of shocks, rear has a dent but was ok when on my car)
been off for a while now since i installed coilovers so condition may have changed - $100ono
- veilside rear bar for r32 gtst, brand new never fitted or used - $100ono
- front gtst cloth seats, need a vacuum and clean - $80ono
- r32 sedan bootlid and type m sedan spoiler, one tiny dent near boot lock - $80ono
- s14 non hicas powersteering pump and resivoir and bracket (decided to keep my hicas pump) - $100ono
may add few other things if i can find in next few days
have a few 32 sedan doors and door trims will have to pull them out
Parts are located in melb
pm or email me for any questions
Cheers Nick
f**k
Where were you a few weeks ago! :blush:
LOL yeh i saw that but didnt think i was gona be selling off this stuff
you can still buy them if it happens again :)
PM's replyed :)
got a model number mate?
would the non hicas power steering pump work in a r32 gtst? pm'd about guards
Im not to sure if itll fit, you will have to find out
Could you please email a pic of the guards to emma@option1garage.com.au
Thanks!
Email sent :D
Cheers Nick
i don't suppose you know if the speaker grills in the front doors are the same as the 2 door ones?
if they are, would you be willing to post a pair of them to brissy?
sorry forgot to reply man been kinda busy
yeh they arnt in the best condition, both have fairly bad dents in them and i wouldnt recommend using them
Cheers Nick
let me guess u are not willing to sell the rubber seals in the doors? i m assuming its off a 4 door 32 expecting a no but i can only ask
pm reply
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
