just thought i'd share some info ... my company produces alot of stuff and ships it all over australia, so when i had to send a set of suspension i told the guys to do it for me and they said to use this company http://www.startrackexpress.com.au/
rates are so cheap .. a full set of suspension .. weighing probably 30 kg's will cost about 20 bucks from adelaide to melbourne... and be delivered the next day!!! over 10 years my company has never ever been late nor has anything been lost!! and they have depots all over the place!!! let me know if theres another place that can do it better and cheaper :D
https://www.sau.com.au/forums/topic/23507-shipping-big-heavy-stuff/
hey scotty .. u know i got told today and u can just ring up the place and use the account number that u will see on it ... and they will charge my company and they will even pick the stuff up from ur place ... u won't have to do a thing .. just make sure its packed good .. just try and use the same boxes that came with my stuff ... my friends at work did it all for me .. i didnt' have to worry about a thing it was that easy!!! .... but pm me later with ur number and i'll call u to tell u what to do ..
if they did ship international what they would have to do is hire another company over there to do the work there .... like if overseas companies send here they usually hire a local company i think ... i doubt it be cheap ... but to tassie?? ui'm pretty sure it will come under 200 easily for an engine ... i'm betting 150-100 bucks ... u just have to make sure its boxed .. cause its charge on the size or weight .. whatever costs more ..
yeh i understand its not based on weight its the amount of area it takes up in their truck/van/boat/plane
mate got his SR20+Gbox from adelaide to hobart for under $200 in little over a week. they picked up the pallet from the importer, and phoned him when it was ready to pickup in hobart. all he had to do was drive down there with a trailer and they dropped it on there.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
