R34 Alternator, R32gtst Spare Wheel, R33gtst Rims With Semi Slicks
What are you running? I've got a seqy in my car.. check my profile.
@ChrisW434 If tuning is new to you, this might be really useful - https://evansperformanceacademy.vhx.tv/ They run a subscription model, so for $50 USD you get access to 100% of the content. Turn it on, watch like crazy for a month and turn it off. The value is crazy. This is how I learnt to tune many years ago. Since then, I go back to the site every couple of years to catch up on new content. I wish HPA ran the same pricing, they are so expensive in comparison lol. -
I mean ideally trims are there because base tables are never 100% accurate. You want them to be as accurate as you can possibly get them, but temperature variations, different altitude, heat, everything likes to mess with how accurate a base table can be. Fuel trims and Narrowband/Wideband fuel control exist to realistically fill this gap/fuzzy factor, and do their job great. But while they will drag your AFR/Lambda to a target, you want them to have to do as little work as possible. Don't tweak any of this stuff without a wideband. Unless it's something like "Disable 'Ghost Cam' because it's very obvious when looking into the Tune", you are guessing with regards to your AFR. You are absolutely right and it's far better to spend the money on a Wideband controller (especially with haltech) and the fab to get it plumbed in NOT where the narrowbands sit (it is supposed to be 1 meter from the turbo), and teach yourself all this little finicky stuff. This is stuff no tuner can ever really be expected to get perfect, but the owner of the car will see SO much livability improvements by learning and tweaking these things - With the proper tools. It IS the difference between "Oh yeah my tuned car drives a bit like a tuned car" and "My car drives like a factory car" It does take a lot of time and tweaking and fun, but you'd never want to be paying $150 an hour for someone else to spend that much time on it.
All sounds good, thanks for that. I'm not starting from scratch as the car is tuned prob 95% just trying to clean up drivability myself as it's obviously really expensive to keep paying a tuner for diminishing returns. The fuel tables are set up decent, as is the basic setup.. i think
