Hey guys
I'v had my skyline now for about 6 months, I really love it, drives nicely and my misses loves it :)
2 weeks ago I had an alarm installed by autobarn. They did a good job it works well and they didnt leave to much of a mess... haha.
I took it back 2 days later becuase I noticed a rattle near the ignition (They put a hole near my ignition for LED light). They said they fixed it.
Tonight, driving home on a smooth road, I could hear the rattle... God its shitting me off. It sounds like a screw is just sitting somewhere, completely out of its socket. Just sitting there.
I ain't going back to autobarn as its a fair drive away to be told they have already fixed the rattle... Any tips on where to look and any tips on taking off panels. I'v never taken a single panel off the car as my interior is very clean and I dont want to snap any clips etc... Any tips/suggestions at all is appreciated... A bit stuck on what to do next.
https://www.sau.com.au/forums/topic/235122-r33-interior-rattle/
Hey guys
maybe you can try knocking the area where you hear the rattle to make sure that it is a screw when the car is stationary. If it is, try to locate it and removing panel off the car and DIY is not a bad thing afterall. you will learn more at the same time. :blush:
just be careful with the clips around.
Good Luck. :)
I have tried bumping the dash, the wheel and all around that area... nothing... Iv even tried shaking it pretty hard lol... dont want to do it to hard though... Nothing...
This rattle is a stealthy little rat :@
And yeh, I'm definitley not keen on going back to autobarn...
under ur steering wheel there r 4-5 screws... undo them, move the steering wheel column down as far as it will go and unclip the cover around the ignition... its very easy... perhaps u mite c something thats loose?
ah thanks for that gumflapper... I will try that in the morning becuase I oringally held the keys while driving becuase I thought that was the rattle (The new alarm remote)...
Cheers for the mini tut hehe... will try that in the morning; I bet you are spot on! cheers again
put the drivers seat right back, get down on your back with a torch and shove your head next to the throttle pedal and look upwards. you might see something thats loose, if no luck, start tearing stuff apart and do what gumflapper said.
They did leave lots of shit in my steerwheel the scumbags lol... But none of that heavy enough to make that sound
After driving last night, sounds more like its coming from the right air vent... the one between the driver right and the demisters (just above the driver right)... I took out the plastic cover and shoved my hand in as far as I could go but nothing... Will have to take off the plastic face...
will go look for the DIY now
I'm a rattle NAZI. Find an audio installer (not a workshop, they most likely won't want this fiddly work) who is confident with Skyline interiors, or at least rattles in general but before giving him the car, go find a section of road where you can make the noise happen. Then take the guy out on the road and show him and ask him to fix it. Unless you have shown someone the sound/problem, you can't be certain they fixed it.
By the way, those air vents DO start to rattle, it's a foible of skylines (and other cars I've owned). My audio guy reduced it a lot, can't remember how tho
Edited by sl33py
I took off the facia and played around in there... I thought I found it (The corner of the plastic odometre) and glued that down... Not the rattle... god I really hate rattles now lol.
Looks like Id have to take the dash off... I really don't want to do that if possible.
Does anyone have any pictures of the right hand side without the dash and facia... I would really appreciate that.
Here is where the rattle sound is...
(Bumping the dash and wheel etc... dont cause the sound to appear... you need to be driving over very small bumps/vibrations)
Quote from a drift battle or hpi -
"The first thing I do when I get a new car is install a really loud stereo so I dont hear any of the creaks."
If you can't hear it, there is nothing wrong :P Mind you I think he was reffering to the lovely creaks thanks to having no sound deadner, cage installed, 2 way diff and solid suspension.
I would really appreciate it if anyone could get me a photo of that area I showed... preferably taken from the top if possible...
I think the rattle is coming more from the back of the dash now... if I had a photo I think I would be able to pick what it is.
cheers
Some annoying rattles & squeeks can be diminished or even eliminated by using 'Silicon Spray' with its little red straw attached.
If Auto**** disturbed or removed/replaced any fitments around the dash, they sometimes don't sit the way they did before.
Try it and see 'er hear!
Tez
yah thats the idea... I'm ready to use it... when I can find it! But I can't see everything that could possibly be making that noise. Thats why I am asking for the pic
I saw some pics on a DIY dash removal on the sau forums, but I couldn't see that area of the dash very well.
Looks like nothing but a vent is in that area anyway :S
Someone soon is going to put up a Post where...
he suggests that you do what FloydWestwood (aka David) said in #9, but do it whilst your GF is driving it.
All 5 senses now come into PLAY!
Hearing = use a stethascope (I can lend you one from the pharmacy)
Sight = Look Up
Touch = Feel Around
Smell = N/A
Taste = N/A
Oops, looks like someone's doing it! :cool:
ah... got rid of the rattle... The rattle came from outside the car. Took off the black casing that is below the windscreen wipers...
There is a glued strip of rubberish plastic that goes between that casing and the window. The last 4-5 inches (the drivers side) was not glued on properly... reglued and rattle completely gone.
Can't beleive it was that becuase everyone agrees the sound came from the inside vent near the steering wheel. hah
Cheers for everyones help! Much appreciated! ;)
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
