Hi Guys!!!
I have 1994 S1 R33 GTST complete for wrecking, car is still complete and running due to i cant sell the complete car and i really needed the money so im going to have to wrecked.
Car had just over 100 000 klms on clock been sitting for a while now. Car is gun metal grey in colour. Car is complied.
Engine complete r33 series 1 (standard) with 100 000 klms on clock $2000 harness ecu turbo .
Complete 5 speed conversion gear box and the rest $2000
Front windscreen $100
Rear windscreen $200
Side quater window $50 each
Standard fmi with pipe $50
Cat back exhaust $200
S1 AFM $115
Quick shift kid $100
climate control $50
charcoal cannister $30 (smaller size type)
ac Fan $80
hub/fan $150
Radiator $150
rad. shroud $50
Condensor s1 $100
gaurds $100
s1 front bar $200
Front bar enforcment support $150
bonnet $250
side skirts $150 pair
s1 cluster $230 with 100 000klms...
s2 front grill $100
rear tailghts $250 complete
rear bar $100
rear garnish $70
Rear pod $80
Doors $50 each
Window motor $140
Window maganisium $50
Front Lh, RH glass $60 each
Door mirror $70 each
boot lid $100
s2 boot spoiler $150
drivers window switch $120
Passenger side $60
complete interior $200 minus rear seat......happy to separate seats trims etc.....
Adjustable coilovers $900 for the set fronts and rears
Rear diff $400
rear / front lower control arms $100 each
R34 Gt rim a set with good rubber $300
complete 5 stud conversion $800..happy to separate suspension also..........
happy to separate the shell eg Radiator support, rears quaters etc.
PLEASE ASK IF I LEFT ANYTHING OUT.
Edited by erwin_skyline
https://www.sau.com.au/forums/topic/235161-r33-gtst-complete-car-for-wrecking/
  • Replies 44
how much for complete car without motor and box?
Hi Guys!!!
S1 AFM $115
climate control $50
ac Fan $80
hub/fan $150
Radiator $150
rad. shroud $50
Condensor s1 $100
gaurds $100
s1 front bar $200
bonnet $250
s2 front grill $100
rear bar $100
rear garnish $70
Rear pod $80
Doors $50 each
Window motor $140
boot lid $100
Passenger side $60
Rear diff $400
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
