  • Replies 44
R32 GTR 2 front seat $500.
$150 for the rear
R33 Gtst front and rear strut brace bar $200
R33 GTST rear coil over HKS and coil over for the front not sure what brand $800
R33 GTST rear diff and drive shaft $600
Edited by erwin_skyline
mate interested in the dash cluster, but i only need the tacho as mines playin up, the rest is a waste for me
pm me with ur best price for it as im interested
pick in syd can be arranged
:bunny:
Hey mate is the drivers side window switch still available, if it is i'm just wondering what order are the pins on the back of the switch in becuase there a couple of different types i'm after the one with 8 large pins on top and 3 smaller ones in the bottom corner.
Cheers
Cheers
hi mate i have attach some picture for you hope this wil help you out.
hey mate,
just confirming, the left hand side door, still avail? your car color, gun metal grey?, any damage on the door panel? if not, doors, i'll come pick up asap
cheers
Hi mate door still avail there no damage on the door. it a gun metal grey door.
sorry dude got home a bit late last night
do you want to pick it up later this evening say about 7.30pm
hey mate thanks for the pics, i'm pretty sure its the one i'm after.
Just wondering if you are able to post to Gold Coast, 4218 at my expense obviously.
PM me with price if you are able to.
Cheers
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
