Ok i finally got my first Vi-PEC in to tune last week and put simply it went extremely well... for two reasons.
First reason is the installation and setup time is around the same as a POWERFC D-JETRO... plug the unit in and fit the intake temp sensor to the manifold or piping whatever your fancy.
Secondly and i suppose most importantly for me was the software was instantly recognisable as LINK which i have used in the past so it saved me the hassle of learning new hotkeys, map navigation and so forth.
The Vi-PEC is a highly capable unit and is a breeze to tune but, is it any differrent to the run-of-the mill G4 plug in LINK? i think not but if both are priced the same i can see no issue either way, the benefit being it is twice as easy to source and is now well backed locally.
The car i fitted it to was a SERII R33 with FMIC, full exhuast and a profec b spec II
Peak power was 210rkw after final tune and peak torque was 346nm @ 11psi without the dip in the graph which was boost controller setup. I attached the last run i saved for refference.
Edited by URAS
Are you retailer for the vipec units now? if so what are you selling them for?
not yet as the current Vi-PEC structure does not work, i have to buy off another melbourne workshop that does not even keep stock and there is also the pricing issue.... there is no profit in them. At the moment i am lining the Melbourne distributors pocket and gettng nothing.
I will probably speak to a couple of LINK distributors before making any further decisions.
RRP on the Vi-Pec is $1666.
Edited by URAS
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
