Hey wondering if i can get some knowledgeable opinions...
First of all, just so you know im talking about non-modified, turbo, automatic examples...
I had an r34 for a few months before a taxi hit me from behind and wrote it off...
Ive test driven a few r33's in my time and I cant help but feel that they are more responsive engine wise, dare i say they feel faster. May just be my impressions...
Also I was under the impression that the r34 used less fuel than the r33... is this true? I noticed when i had my r34 that fuel consumption was reasonably high.
Basically I have 18k to spend... I could get a nice r33 for 12k and spend the extra money on alarms, a front bar, rear bar, dvd player, or whatever. Or i could get another r34 for about 16k, basic model and not really be able to afford any luxuries for it.
What is your opinion? Thanks :D
https://www.sau.com.au/forums/topic/235183-buying-r33-or-r34/
as you said if you get r33 you can spend money on other things, unless its a series 2 you will need a body kit IMO, but R34 looks fine stock !
As far as fuel economy goes the NEO is supposed to be more efficient, and the 34 has more power so should be faster, but i havent driven either so cant speak of which feels more responsive. Maybe someone with experience in both can shed some light on if the 34 has slightly more lag ?
a 34 WILL beat a 33, but if you just want to feel like your going fast, then if it turns out a 33 is more responsive maybe thats better for you ?
basically i think if youve had a 34 before and your having to second guess it maybe you really want the 33 so you can do more stuff to it, so perhaps that is your answer ? :D
Hey mate,
bummer about the first r34. We've seeing r34 sales definitely outnumbering r33 sales lately, but if you can find a mint 33 that might be a good option for you. We've got an auto coupe turbo 34 coming in, selling for $14,900 after compliance (wholesale price). more info on our ebay page.
basically the body is pretty different, so choose whichever one you prefer lookswise. You can get great performance out of either.
cheers,
David @ Carizma
What is your opinion? Thanks :dry:
Hey mate,
cheers,
David @ Carizma
How much is that all up?? I have a max of 18 but that has to include 1k for insurance and also rego and also stamp duty...
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
