Hello,
My r34 was written off by a taxi last week, the insurance company is about to sell her off. They said i can take out the dvd screen if i like...
It is a 7inch fold out unit, connected to a sony dvd player. I will have to leave the dvd player in but i can take the screen.
Is it worth my time ?? (its far away for me and i have no idea how to remove but i suppose i could follow chris roger's guide...) Is it hard to remove?
Could i connect it to an australian PAL dvd player unit and would it work fine?
Thanks muchly :D
https://www.sau.com.au/forums/topic/235184-jap-dvd-screen-worth-removing/
yep rip it out. it will need a NTSC feed to work though. JVC do a 7 series unit that will work with it.
thanks Chris you are a great help, used your guide got it out fine! Really appreciate it :P
The guy from the insurance company came out, tried to help with getting it out of the bracket... He yanked at it pretty hard and the foldout screen bit came out a little, but it managed to go back in, it should still work probably??
Also you are not in melbourne are you? Can you recommend anyone in melbourne to install the wiring etc.
thanks again :P
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
