just drive normally and youll be fine
you will only have troulbe if you load the engine up
the std service manual tells you specs for snow chains and how to fit them
id strongly advise getting a normal car for the snow however
Thanks all, I was at Hotham a couple of weeks back when it was snowing heavily and the roads were closed, but I had a mitsubushi outlander and it was a piece of piss to drive in the snow (slow speeds). Im not out to break any mountian climb records but thought it might be a nice drive and save me hiring a car again.
There is now much more variety of snow chains available with scratch protectors etc but Im keen to know if anyone has fitted any chains to their R32 GTR and wether its front or back wheels, and wether they foul on the wheel arch liner?
Cheers, Sandy.
not as obvious as you might think, lotsa new 4wds advise chains on the front wheels, is good to combat understeer aswell as traction issues, admittedly they also drive mainly from the front. Id like to know what nissan reccomend for the GTR.
Sandy
You're pacifically asking about the 32 are you?
I went up to Lake Mountain a few weeks back in my R33 GTST. There wasnt much snow on the road as most was ploughed off, it was still very slippery though. If the road is like that you should be fine without chains, just drive slow and off boost.
Lake mt to Hotham is like Mt Buller compare to Niseko Japan! I took my old 33gtst to Buller along time ago, the car is fine, just drive within your limit.
Could be a bit of overkil with chains on all 4 wheels (have to hire and fit em), does anyone know what nissan recommend for the R32 GTR?
Why dont' you ring up NISSAN themself?
Though it sounds like alot of fun, still, taking a GTR to the snow isn't the best idea as you'd imagine the Attessa System will be working over-time for sure.
unless you absoloutely had to i wouldnt do it. GT'R is about the last car i'd want to take up to the snow. heavy on fuel, bugger all room for bags, bugger all room for people inside without it turning into a fogged up sauna, and i can only imagine it would wreak havoc on the attessa system - wouldnt know what was going on!
Niseko?
Haha. I really havent been to Hotham or Buller before so I have no idea what either was like.
Just put chains on the rear wheels and take it easy. Stay in Second whenever you're on the snow/ice - even when taking off.
As soon as you've driven the first 10m with chains you'll know what you're dealing with.
I just bought some Konig chains for this season - if you get the correct size they won't scratch your rims (they barely touch them).
One thing to note however is the clearance from guards/suspension, if the car is excessively lowered or has extra wide rims forget it.
PS. Chains are very important - just ask this guy (up to Mt Baw Baw 17/08/08)
i went to bullar in my s2 stagea ... no worries didnt even bother with chains .. no slip at all .. plus the traffic i was behind, i was doin a max of about 30k's up and down ... so i dont see any reason too .. just to save money and time and have a smooth ride now a ride that feel's like you have flat tyers driving over bricks :O
I've driven the back roads from Lake Mountain to Reefton in an R31 two years ago whilst snowing
with no chains. No the most pleasant experience.
Simply kept the car in 1 and/or 2nd gear (auto) and keep the speed at 20km or less with no sudden acceleration to cause the tail to kick out or put you into an aquaplain, also or no sudden decelelarion (compression lockup) to have the tail kick out.
Same with the steering, no sudden turns, keep it smooth.
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
