I Beleive the the cat you can use and defintely the jjr bellmouth fits (i'm getting that) but the catback exhaust system I beleive you can't - the bends are different. the Stagea Cat backs are pretty much straight whereas the R33 has a bend after the diff.
Plus I don't think the R33 exhaust will reach all the way through.
As I said this is my rough guess...so to answer your question - it can get expensive to modify your exhaust. best bet custom build it and sell the R33 exhaust
Looks like it'll be too much stuffing around trying to fot a R33 exhaust then.
How about this, 3" bellmouth, 3" hi flow cat, 2.5" cat back... is that bad or even possible?
thanks.
Thats all im running in mine. A 3inch r33 xforce front pipe and 3 inch high flow cat and the standard 2.5inch cat back system. Ull notice a slight power gain and it wont do any harm.
go 3 inch all the way- no sense in introducing any restrictions that are not needed
we have a 3 inch full system now - not too noisy at all !
got the JJR Bellmouth and Cat - and we already had an existing 3 inch catback system
good luck ! pm me if you need any details- I had a bit of screwing around to do to get it rught
It pays to try the search button first before starting a new thread;
I have an R32GTR Nismo exhaust on my Stagea. It was quiet, but effective on the GTR (300 rwkw) and seems equally so on the Stagea. Makes no more noise than standard at up to 3,000 rpm, so great from highway running perspective, zero resonance. Over 3,000 rpm it allows the normal RB type howl, audible but never annoying.
The guys at Liverpool Exhaust and I modified it to fit the Stagea, added around 100 mm before the rear subframe and around 80 mm after the rear muffler (ie; extended the tail pipe). Then simply moved the exhaust hangers to suite the Stagea.
The R33 exhaust is pretty much the same as the R32, just different hanger location. The Stagea hangers look like the R33 ones so my gues is you wouldn't have to move them like I did with the R32 exhaust.
Cheers
Gary
Yes i did search and yeah i read that, but wasn't sure about the r32 and r33 differences.
Ok cool, so looks like not too much buggering around then.
Another question, apparently the r33 cat fits right? how about the r34 cat? will that fit nicely?
Cheers
Gary
cats are cats mate. all the bolt in ones are the same length.
the easiest way is to get most of it sorted (eg buy a front pipe and cat back) and then give it to an exhaust shop for the required minor adjustments
Alright, so it looks like i will get the jjr bellmouth, an r34 metal cat and a r33 aftermarket catback and hopefully the exhaust shop can install without too much difficulty. :D
Nick, Im 99% positive my catback exhaust 3" pipe is originally from a R33 (sedan?). from cat to pre-diff its normal, but there is a cut and welded section (have a kneel underneath. want to catch up?) where a bend was potentially cut out and a straight section welded on, then my Kakimoto Racing GTR 3" in/out centre/centre muffler is welded on. JJR bell dump, Random tech race cat, cat back pipe & Kakimoto Racing gtr muffler, all under $700 fitted.
definately do-able, just take all the parts to exhaust shop and tell them to make them fit. I use morphett vale Carline Mufflers. they'll be able to do it no probs
Thanks Brendon, just wanted to make sure before i pass over my hard earned $$. :blink:
what xforce muffler did you get??
cant post a pic ...cant even save it but if u go to there web ... xforce.com go to mufflers , then go to the twin tip section and go 3rd down in the middle MPO1 ..... trying to keep it looking standerd ... havent got it yet .... soonish
You need a twin 4" muffler...
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
