hey all
got an R32 GTR
it has an Apparent OS Giken Triple plate clutch in it, this thing has f all friction point and just grabs so i assume its some sort of aftermarket thing
now the problem is
its perfect when driving no problems shifting at high revs or anything like that just a few noted below
sometimes i start the car up after driving for a bit and push the clutch pedal down to engage gear it will not let me select a gear have to switch the car off then select gear then hold the pedal down but even then it will lurch forward and start to move, sometimes i will rev it to like 5k try and select and it will just grind a bit and still will not select the gear..
and sometimes coming up my driveway i select first and disengage the clutch but then when i put my foot down to deselct first it will still say in gear and stall?
anyone know what will cause these problems?
should i adjust the master cyl pushrod? bleed the system, change the fluid?
Thanks for your help
Edited by urbanoperations
https://www.sau.com.au/forums/topic/235225-r32-gtr-clutch-problem/
sadly, if it happens intermittently it's most likely, a damaged/bent clutch fork, or damaged bearing carrier, or worse damaged pressure plate. that is why sometimes it's fine, and sometimes the clutch wont disengage.
  • 3 weeks later...
