For Sale Skyline R32 4dr
Item: 4 door r32
Website:
Item Condition: exelent
Reason for Selling: got to many bills
Price and Payment Conditions: $13500 ono URGENT SALE MAKE AN OFFER
Extra Info:
`hybrid intercooler
`oil cooler with remote oil filter
`power steering cooler
`alloy radiator
`oil catch can
`head has all been redone about 1000ks ago with arp head studs new water pump and thermostat
`3" turbo back exhaust t3 to4e with 38mm wastegate with screamer
`HSD HR coilovers only about 2000ks old
`ajustable radius rods
`pineapples
`extra steering lock kit
`hicas locka bar
`strut braces
`button clutch 1000ks old
`shimmed diff (locked)
`guages .boost. oil temp. oil press. water temp.
`stereo
`turbo timmer
`18" mags with new rubber
`always well looked after and garaged and serviced
`rwc rego
Pictures:
Contact Details: phone 0413 063 623
im not on the net that often so just call for any enquiries
This post has been edited by drift4dr: Today, 06:17 PM
Attached thumbnail(s)
  • 1 month later...
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
