nengun has them for the HKS GTRS for:11004-AN008To Suit ECR33 RB25DET S1 & S2 93/9-98/5AU $ 2,467.65
Anyone know of anyone who could beat that price?
Thats the price excluding delivery. Because of the bad exchange rate its going to be 2760 delivered. When last month it was 2400 delivered. You have to sign up to nengun to get postage costs.
PM Slide, i think he can do the HKS GTRS kit a bit cheaper.
Honestly don't worry about "if the turbo fails its going to blow the engine" because it isn't!
It is very, very rare for parts of the exhaust wheel to go upwards into the exhaust manifold and into a valve. Most of the time the exhaust wheel and shaft end up in your cat. If your unlucky enough the compressor wheel will let go and end up in an intercooler. For some of those parts to get through into your engine is rare so honestly if you don't actually want an upgrade because you want more power, only due to you being worried, then just leave the turbo as it is.
Turbo upgrades blow $5000+ easily out of your wallet when you include:
turbo $1000-$2500
ecu $1000-$1500
Z32 AFM $200 (if not MAP sensored)
fuel pump $200-$300
injectors $600
clutch $500-$1000
splitfire coilpacks $450
tune $400-$600
intercooler/exhaust/silcone/etc etc
Labour if you aren't doing anything yourself... $1000-$1500
It all adds up man. Now whats better, leaving the car as it is, or spending that much money just to make sure the turbo doesn't let go.... Your call.
Edited by PM-R33
Very true indeed... Only upgrade it if you really need or want the extra power. If its just an excuse for your mrs then just keep her away from this thread :ninja:
for a cheaper option go a gcg highflow and keep total output to 230rwkw and you should get away with stock injectors, afm and fuel pump
Very true indeed... Only upgrade it if you really need or want the extra power. If its just an excuse for your mrs then just keep her away from this thread :blink:
Thanks for all the replys, very much appreicated!
I always had the intention of doing injectors, fuel pump and airflow meter anyway.
Im really interested in the HKS GT-RS bolt on kit, initially was turned off by the Just Jap Price of $3800, but when i realised nungun and slide where doing them for a grand cheaper, it has sparked my interest!
New Question for the day. Do the 300zx T/T stock injectors (430cc/min) fit the rb25det?
or is it the same story as the gtr injectors top v's side feed?
2nd Question for the day. Would the Greddy Emanage Blue be a satisfactory piggyback ECU to run my desired tune/setup outline in first post?
Cheers.
Jason
Edited by Housie
The e manage can handle those power levels quite well afaik...
Greddy run them on plenty of their highly modifyed demo cars
also make sure you look at the hks 2835 pro s kit. Its a thousand schmux more but it makes an easy 260 to 280rwkw depending on supporting mods and tune.
I'm running mine in conjunction with an ex cam gear and have 265rwkw but spooling up as early as the gtrs. It also makes 245 on a lazy 1 bar with full boost by around 3500 and without having to run at its limits
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
