*** Hd Clutch Group Buy #2 ***
these are factory direct prices man i put nothing on top of what Doug is charging me i don't think its right i make a profit out of other enthusiast's that want a good deal also
  • Replies 52
I may very well want a single and fly but my car is in customs quarantine yet and I want the compliance guy to check it out before i commit because it may already have an A/M in it and do not want to spend $1k right now if I do not have to.....
I should know late next week.
I guess if you go ahead with the buy before is there any chance that you could speak with your supplier and ask him if he can allow one extra purchase at GB price in the next few weeks, Ill understand if he says no in which case I will wait for the next run.
thanks dood
Bob its not looking promising on the flywheels and its even been slow on the clutch side of things i started this group buy due to a few people wanting them local to me and now i only have 1 clutch sold
/2on hasn't confirmed that he wants either any more
Fabs_32 only wants the clutch now but @ least he has paid for it
Andrew. M has pulled out due to going over seas but he was a pretty big maybe
and boy it sux not being able to edit the first post
its a 5puk Ceramic 1200+kg pressure plate Rated to 350rwkw or about 300awkw
its built by NPC with the Excedy pressure plate and nismo springs on a 4.2 patrol machined down centre
ok i have 2 options to run with ring Doug tomorrow and see if he will fullfill my order of 1 and close the group buy or extend the group buy for 2 more weeks
hey mate,
stick me down for the 5 puck clutch, that will make the minimum of 4 people for the group buy to go ahead.
I'll need the push type to suit a r33 gtst
I'll transfer the money now for you
:P
it would of made the minimum if Ron and Craig had paid since it is a short week this week ill leave the group buy open and ill ring Doug over the next couple of days
EDIT
R34GTFOUR - payment received
sorry Steve i have no idea if all went well it would of closed already with the required amount of people wanting clutches and flywheels
at a guess maybe next friday if i place the order next tuesday im going to try and scrape up $580 and make up order #3
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
