He was lucky to get away with the speeding fine. Quick thinking on his part
but i think he deserved the yellow sticker tbh. Not for the no lights in the dash, but for the rear lights being off.
We all got to agree that is pretty dangerous more so cause his car was black/gmg (cant remember)... and if it was as simple as a "fuse", wouldnt be easy to put one in and he would of avoided all the problems and hassles...
thats my 2cents anyway
maybe he really didnt know they were out, or is it a feature in jap cars ur dash lights go out with ur tail lights, also he did say he was on the way to the servo so they coulda let him get one there
  • Replies 54
i think they run on the same fuse...
If that were true (and ill give him the benefit of the doubt since he drives a skyline haha ) somehow i dont think most police would believe that...
Also im sure the servo is left onto south street not more down murdoch drive :)
But anyway, i 100% agree on what he said about the rust buckets on the road... they never seem to get stickered...
Edited by br3ndan
No excuses for driving without lights. How can you not notice your dash lights not working.
Then if they weren't working anyone with half a brain would check the rest of the lights.
well i would 1) to be considerate to other drivers
2)cause i dont want someone running up my ass.
he should be thankfull with the $200 (pull your head in) fine. Tosser
The first night I got my P's I got pulled over in my dad's bunky Holden Camira. It looked like a shotty drug dealer car, home job green paint, and black boot.
Got pulled over coz it was blowin some smoke. They noticed my dash was out (brake lights were fine). But I had a lil torch taped to the dash so I could see the speedo. :P
They were gona yellow me but because it was my dad's car, they let me off and said to get it fixed.
If it was just the dash in Willem's case I'm sure it would have been the same, but no rear lights is as everyone stated, stupid.
Edited by Magic
I was more concerned with the fact that his break lights weren't working, thats hell dangerous even in broad day light.
i thought his brake lights were working? towards the end of the segment you could see them light up. or maybe i'm wrong
brake lights were working, just normal taillights didnt come on, my car did this, turned out to be a fuse and a shitty wiring
I had the same fuse go on my car the other week, when I was setting off to Rockingham to watch my son play hockey. I did not realise the tail lights were out as well until I got there. I was guessing my speed the whole way - basically matching speed with other traffic. Then I had to drive back! Not fun.
The sensationalist coverage really bugs me. He was quite right to point out about the rust buckets, but unfortunately no rear lights is dangerous at night (not a problem in the daylight). But you would thought he was an axe-murdering rapist.
The only thing they did not say was that by not allowing him to go to the servo and buy a small fuse, they were preventing a small child from choking on it!
Thank heavens for Channel 7.
Tossers!
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
