hello,
i just paid $165 to get a greddy profec b ii installed. naturally i was very excited and couldnt wait to try out my new gadget. attempting to set the thing up was irritating at first, because i didnt seem to be able to get very good live readings, and the peak boost results were often ridiculous, ranging from 1.6psi, to 23.5psi, despite the car not feeling any different on either run.
i have searched and figured out the tuning now, thanks to a very helpful guide i found. but turns out the ebc was set up all wrong. the hoses to the actuator and the compressor housing were the wrong fkn way around! and the pressure sensor was ludicrously connected to the "NC" (which is for external wastegate). i have no idea how you can get it so fkn wrong! clearly the pressure sensor should be connected to something pressurised.... like the manifold maybe...
i have a question though, the manual says "NO" to the compressor housing, and "COM" to the actuator (internal gate). i changed it to this because it was the other way around, but i just want to confirm its correct if anyone knows. oh and the pressure sensor connects to the fuel pressure regulator right?
now i have to try and dial in 18psi with the stupid % set boost function. what is with that?
lol at modifying cars.
need some splitfires too. anyone know of performance coilpacks in blue or yellow (to match my engine bay)??
https://www.sau.com.au/forums/topic/235266-idiotic-ebc-install/
Yes that's correct. Just as it says in the manual :(
So the "NO" needs a pressure signal from intercooler piping or compressor housing or somewhere there, "COM" goes to the actuator. And the pressure sensor for the unit, just T it out of one of the hoses from the plenum. As you said, fuel pressure reg vac line, it's the most easily acessed.
Think of it like this
NO=normally open
NC=normally closed
COM=common
If there was to be a failure of the solenoid for an internal gate car you want it to be flowing air, so you don't run huge boost levels, so you use NO and COM
If there was to be a failure of the solenoid for an external gate car you don't want it to be flowing air (its connected to top of the wastegate to hold it down), so you don't run huge boost levels, so you use NC and COM
think of it like an interceptor
the unit needs manifold pressure
so that is seperate
then it needs a signal in (intercept it) and signal out
so it takes signal in from the manifold again and then intercepts it (this is where it bleeds pressure in/out) and then signal out goes to the actuator
so the controller sits in the middle and lies about pressure to the actuator
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
