Wrecking R32 Gtr All Part Avalible
Hi All
Wrecking an Gun Metal Grey R32 GTR Skyline with 92,000kms
All parts Must Go!
Shell is a complied un-rego'd 93 gun metal grey but chassis rails damaged beyond repair,
Thanks Joel
p.s. all parts but Engine and brakes are Avalible!!
prices are a guess of there value and are only there to stop the thread closing, all price are neg.
this includes but not limited to:
-16" Sparco Racing Rims to suit nissan 5 stud patten, $1200
-Gear Box, SOLD
-GTR Bonnet,SOLD
-GTR Grill Insert,SOLD
-Clutch master cylinder, $50
-Power steering pump, $70
-Power steering resivar, $30
-Master Brake cylinder, $50
-Abs System,SOLD
-GTR Fuel Tank,SOLD
-GTR Fuel Pump,SOLD
-GTST Rims (had from last car around), $100
-GTR Front right Gard, minor damaged $30
-GTR Rear Bar, $100
-GTR Boot Lip, $100
-GTR Rear Wing (spoiler), damaged But repair-able if your good at fiberglass $20
-GTR Instrument cluster w/ 92,000km, SOLD
-GTR Swayd door inserts,$50
-GTR Springs,$70
-GTR Swaybars, $50
-GTR Airbox, $40
-GTR radiator,$70
-GTR front cross member, $100
-GTR Steering rack, $50
-Seat belts $20
-Front Bumper Reo,SOLD
-Rear Bumper Reo, $100
-Head Lights, $300 for pair
-Right Tail Light, $50
-Reversing Lights $20
-Dash, $100
-Glove Box, $25
-Center Console, $30
-A/C controls, $30
-Steering colum arms, $30
-Radiator overflow, $20
-Washer bottle, $20
ask for a part!
please leave the topic of your PM's with the name of the part, or call me on 0407 18 2002
etc...
pics of sparco wheels? tyres? and i'm guessing gtr front bumper is stuffed?
yes sorry I have sold the Front bumper and latch as well, tyres are yoko c-drive on the front and antyre (ONLY 3 MONTH OLD) all tyres are 235, 45
also a typo its the boot lid i'm selling not the boot lip
thanks Joel
any questions call or msg me on 0407 18 2002
Edited by Crimsonknight
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
