Hey guys just installed some whiteline extra heavy duty sway bars to my GTT and just wanted to say they are awesome. Before the install only had tanabe coilovers, which did a decent job in corners but used to get a lot over oversteer, but now the car is a lot flatter and handles like a dream through the tight twisties :(
For anyone thinking of getting some sway bars i'd definetly say "do it!!", by far the best handling mod i've ever done. Cheers :dry:
https://www.sau.com.au/forums/topic/235329-just-installed-sway-bars/
  • Replies 44
i have been thinking about getting some, but after spending $500 on adjustable bushes (castor/camber) and not noticing f**k all difference i'm a little apprehensive.
im having trouble keeping the back end stable through long corners and im hoping sway bars will fix this.
What mods would be suggested to a R32 GTR's suspension?
ATM I have tein HA coil overs and I just replaced most of the front bush's with nolethane items.
I also run 255 x 40 x 17's on 9inch rims.
any advantage in replacing the standard sway bars with after market items?
I also have front and rear struts.
cheers
rob
I just want it for street use and I guess tidy up the handling abit, make it more responsive ( around corners , speed of steering etc without killing tyres. I'm good with engines but no exp with suspension.
Email the question to whiteline dude along with your current suspension specs eg. toe in, toe out, camber, caster, etc. and they sould be able to give an answer as to your problem. Thats what i did and they recommended sway bars for my oversteer problem.
www.whiteline.com.au
i also put a whiteline non-adjustable extra heavy duty front sway bar in my R33 series2..
was the best money ive spent on suspension so far..
pretty much dont have any understeer anymore, only coz need new front tyres..lol
cant wait to do my rear ;)
  • 6 months later...
ok got my whiteline adjustables and the rear one on first, absolutely loving it!!!
Got around to doing the front and im either retarded or i got the wrong bar because it wont reach to the original links!
I put it up against the old one and its about 4 cm shorter in length... i hope its normal cause i couldnt figure it out
After reading all this good feedback on sway bars I'm thinking this will definitely have to be my next mod.
I have an R32 4dr. What are some of the better brands and what is around a reasonable price to pay for some (front and rear).
I run TEIN Coilovers already.
Thanks alot.
-Jimmy.
Went back to fulcrum and they had given me the wrong front one, so swapped it over all good.
Jimmy - Better brands are much of a muchness, they all do a pretty good job. If you want adjustable ones then i think whiteline are the only people who do that.
Expect to pay around 500
i think i paid 400-450?
should be able to get trade price at repco or bursons
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
