I've got zeh Bilsteins though :( Maybe my stock springs just don't suit the Bilsteins ..which is why I'm thinking of upgrading them to the Whiteline springs from the original GB and get the Whiteline sway bars as well as the same time. Just worried the sway bars might introduce more issues than solve eg. wheels lifting off the ground mid roundabouts when hitting a bump etc
  • Replies 44
Well that should rule out a damper deficiency. Changing springs won't affect it either, in fact a higher spring rate, even as little as the 20% to 25% in the Whiteline springs will increase the impact feeling from bumps. So I wouldn't suggest trying a spring upgrade in an attempt to aleviate some other problem.
You do get a little bit of the impact effect from bumps passed though the swaybar, but it's minimal at worst and usually unnoticeable. The benefits of upgraded anti roll far out ways the negatives. I have ugraded the anti roll in many R32/33/34's way more than you most likely have without casuing any undue bump and chosen line retention issues. For example we slam the race cars into the ripple stips with lots of lateral G force on board without excessive effect from the huge levels anti roll we run. So, in your case, I would look at alignment and worn suspension bushes as a more likely cause.
Cheers
Gary
Cheers
Gary
How can worn bushes effect droop travel? if anything they would help droop travel.
Swaybars give you less droop travel.
In Europe they run their race BMWs with no rear swaybars and really long shocks as they cant run LSDs. This is the only way they can manage traction and not lift wheels everywhere.
They don't but they do affect the handling after hitting bumps, pehaps you need to reread the original question...
what about bumps/potholes though on a daily ? My understanding of the way antisway bars work is if you hit a pot hole say mid roundabout it would be worse than without them ? Happens a lot in the inner city ..seems whenever I turn, wherever I turn there are friggin potholes
Nope, the length of the shock and the free height of the spring determine the droop along with the overall suspension geometry of course.
Who is "they"? I have worked on BMW DTM cars and BMW Production Cars for both the Spa and Nuburgring 24 hours races plus 5 years with BMW SuperTourers here and every single one of them ran/runs swaybars front and rear. Where the regs allow, they are driver adjustable. Hence my question.
Cheers
Gary
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
