1992 Nissan Skyline GTR R32
I have owned this vehicle for about 5 years, I purchased it from Reece McGregor (if you do not know who he is, Google it ) I have spent in excess of $125,000 modifying this vehicle.
Absolutely no expense has been spared. It has taken about 3 of those 5 years to get this car absolutely ready to go, it has been careful broken in and only given a reasonable amount of boost on the dyno (1.5 bar) at this time with c16 gas it made 695 hp at the wheels, allowing for the 28% transmission loss (as quoted by the dyno manufacturer) equates to in excess of 975 hp at the flywheel ! she is reduced to approximately 700 hp at 1 bar with 98 RON pump gas.Since re build she has been only been driven by me at 1 bar with the 98 for about 2000ks,it has not been raced in this time, hence I consider it reasonable to describe the engine and trans as nearly new. Although fitted & plumbed, NOS has never been administered. Despite the massive power this engine generates, it is totally tractable and will pull top gear from 1500rpm, the idle is totally stable at around 900.
Sadly after all this time, I am over it !
Modifications are as follows, there are probably more, but I just can' remember !
ENGINE / INDUCTION
OS Giken RB30 Short Engine
HKS T51r SPL Turbo & Manifold
Weaver Dry Sump System Incorporating Heat Treatments Custom Sump & Morose Holding Tank
Jun inlet 69-11.35lift & Exhaust 68-11.35 lift B29 Camshafts
Jun Metal h-gasket
Race Ported & Port Matched RB 26 Cylinder Head
Nos Direct Port Injection
Custom Race high flow alloy radiator
SX Fuel pressure regulator
Bosch 1000cc Injectors x6
SX Fuel Pump 15oo hp x2, SX Filters x2
Jun Metal h-gasket
Greedy Plenum
Custom made stainless 4 inch exhaust
Nismo engine mounts
TRANSMISSION
OS Giken 5 speed gearset
OS giken RS3 clutch kit
Cusco 1 way RS Differentials Front & Rear
SUSPENSION
HKS fully adjustable hyper drag suspension
Midori front top links
Cusco rear top links
SAS Rear Subframe / Axle Mounting Kit
Custom built chrome moly hicas isolator
WHEELS
BNR34 18 x 9 inch forged alloys for road use shod with Bridgestone potenza 245x40 rear and Pirelli p7000 front
BNR32 16 inch shod with Mickey Thomson drag radials
ELECTRONICS:
MOTEC M8 ECU
HKS ETC (electronic torque splitter) with HKS drag adaptor
EXTERIOR:
tomei drag inlet
INTERIOR:
Leather trimed GTR seats
SARD 5 point race belts
Full Cusco roll cage
HKS oil, exhaust temp gauges & boost gauge.
If you are looking for a serious machine, this is it, you may see cars that look as good in Japan
THEY WONT BE, generally speaking people sell this caliber of vehicle when it is ready to be rebuilt, and make no mistake, with this type of car this will be quite often ! Before I purchased this car I viewed many hard gtr's in Japan,to say the least, most of them were 'tatty' this 32 is one of the best I have seen, inside and out.
This vehicle is fully legal for New Zealand roads, it is NOT an illegal import with the firewall modified, as seen so often here since the frontal impact law !
i AM ON 006421357997 PRICE IS 50K AUSTRALIAN $ [email protected]
https://www.sau.com.au/forums/topic/235340-965-hp-giken-32-gtr/
thats about 530awkw YIKES!!!
did u ever run it on the 1/4 seeing that u have the MT's for it?
I ran it once in two wheel drive, this was my fck up, I stalled during the tyre warm up & bump started her, but forgot to reset the 4wd.
I 'snaked' the whole lengh of the strip thinking wow that was fast ! unfortunatly it was a flat eleven . We all Know what this car is capable of, especially with some weight removed. The nice thing about this one, is the drysump, correctly used, it make the bottom end bullet proof-rare for an high tune RB.
man what a beast i thought i was doing well with 412kw atw !!! this thing would be an awesome car to drive good to see there is still some hard core gtr's out there for sale for reasonable prices. only bad thing is that the market is farked atm so you may be in the same boat as me mate trying to sell hi hp gtr's ..
good luck with your sale , i know if mine sold i would snap this up :(
how responsive is it.. .when does it come on boost with a turbo that big!! couldnt be to about 5 - 6k that it starts to hit boost even though it has an rb30 bottom end... Can you pm the answers to me cheers chris... will consider when sent.
Also could you email a small vid of it running to [email protected]
cheers
chris
cheers
chris
STARTS BOOSTING AT 4 GRAND , BUT WILL PULL TOP FROM 1500RPM, IT IS VERTUALLY AS RESPONSIVE AS A STOCK GTR.
THIS CAR DOES NOT HAVE A RB 30 BOTTOM END-FAR FROM IT. iT HAS A GENNUINE GIKEN STEEL CRANK & RODS RUNNING IN A GIKEN MODIFIED n1 BLOCK THERE IS ABSOLUTLY NO COMPARISON.
IF YOU ARE SERIOUSLY INTERESTED, FLY OVER AND SEE HOW IT RUNS, IF YOU ARE DISSAPOINTED I WILL REFUND YOUR EXPENSES.
Excuse me while I scrape my bottom lip up off my desk. THIS THING IS THE PUNISHER! Holy crap man. The great thing is I love NZ road laws. You can legaly drive a monster like this on the roads. OMG.
GL with the sale. You deserve every cent of this in return.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
