1992 Nissan Skyline GTR R32
I have owned this vehicle for about 5 years, I purchased it from Reece McGregor (if you do not know who he is, Google it ) I have spent in excess of $125,000 modifying this vehicle.
Absolutely no expense has been spared. It has taken about 3 of those 5 years to get this car absolutely ready to go, it has been careful broken in and only given a reasonable amount of boost on the dyno (1.5 bar) at this time with c16 gas it made 695 hp at the wheels, allowing for the 28% transmission loss (as quoted by the dyno manufacturer) equates to in excess of 975 hp at the flywheel ! she is reduced to approximately 700 hp at 1 bar with 98 RON pump gas.Since re build she has been only been driven by me at 1 bar with the 98 for about 2000ks,it has not been raced in this time, hence I consider it reasonable to describe the engine and trans as nearly new. Although fitted & plumbed, NOS has never been administered. Despite the massive power this engine generates, it is totally tractable and will pull top gear from 1500rpm, the idle is totally stable at around 900.
Sadly after all this time, I am over it !
Modifications are as follows, there are probably more, but I just can' remember !
ENGINE / INDUCTION
OS Giken RB30 Short Engine
HKS T51r SPL Turbo & Manifold
Weaver Dry Sump System Incorporating Heat Treatments Custom Sump & Morose Holding Tank
Jun inlet 69-11.35lift & Exhaust 68-11.35 lift B29 Camshafts
Jun Metal h-gasket
Race Ported & Port Matched RB 26 Cylinder Head
Nos Direct Port Injection
Custom Race high flow alloy radiator
SX Fuel pressure regulator
Bosch 1000cc Injectors x6
SX Fuel Pump 15oo hp x2, SX Filters x2
Jun Metal h-gasket
Greedy Plenum
Custom made stainless 4 inch exhaust
Nismo engine mounts
TRANSMISSION
OS Giken 5 speed gearset
OS giken RS3 clutch kit
Cusco 1 way RS Differentials Front & Rear
SUSPENSION
HKS fully adjustable hyper drag suspension
Midori front top links
Cusco rear top links
SAS Rear Subframe / Axle Mounting Kit
Custom built chrome moly hicas isolator
WHEELS
BNR34 18 x 9 inch forged alloys for road use shod with Bridgestone potenza 245x40 rear and Pirelli p7000 front
BNR32 16 inch shod with Mickey Thomson drag radials
ELECTRONICS:
MOTEC M8 ECU
HKS ETC (electronic torque splitter) with HKS drag adaptor
EXTERIOR:
tomei drag inlet
INTERIOR:
Leather trimed GTR seats
SARD 5 point race belts
Full Cusco roll cage
HKS oil, exhaust temp gauges & boost gauge.
If you are looking for a serious machine, this is it, you may see cars that look as good in Japan
THEY WONT BE, generally speaking people sell this caliber of vehicle when it is ready to be rebuilt, and make no mistake, with this type of car this will be quite often ! Before I purchased this car I viewed many hard gtr's in Japan,to say the least, most of them were 'tatty' this 32 is one of the best I have seen, inside and out.
This vehicle is fully legal for New Zealand roads, it is NOT an illegal import with the firewall modified, as seen so often here since the frontal impact law !
i AM ON 006421357997 PRICE IS 50K AUSTRALIAN $ [email protected]
https://www.sau.com.au/forums/topic/235340-965-hp-giken-32-gtr/
thats about 530awkw YIKES!!!
did u ever run it on the 1/4 seeing that u have the MT's for it?
I ran it once in two wheel drive, this was my fck up, I stalled during the tyre warm up & bump started her, but forgot to reset the 4wd.
I 'snaked' the whole lengh of the strip thinking wow that was fast ! unfortunatly it was a flat eleven . We all Know what this car is capable of, especially with some weight removed. The nice thing about this one, is the drysump, correctly used, it make the bottom end bullet proof-rare for an high tune RB.
man what a beast i thought i was doing well with 412kw atw !!! this thing would be an awesome car to drive good to see there is still some hard core gtr's out there for sale for reasonable prices. only bad thing is that the market is farked atm so you may be in the same boat as me mate trying to sell hi hp gtr's ..
good luck with your sale , i know if mine sold i would snap this up :(
how responsive is it.. .when does it come on boost with a turbo that big!! couldnt be to about 5 - 6k that it starts to hit boost even though it has an rb30 bottom end... Can you pm the answers to me cheers chris... will consider when sent.
Also could you email a small vid of it running to [email protected]
cheers
chris
cheers
chris
STARTS BOOSTING AT 4 GRAND , BUT WILL PULL TOP FROM 1500RPM, IT IS VERTUALLY AS RESPONSIVE AS A STOCK GTR.
THIS CAR DOES NOT HAVE A RB 30 BOTTOM END-FAR FROM IT. iT HAS A GENNUINE GIKEN STEEL CRANK & RODS RUNNING IN A GIKEN MODIFIED n1 BLOCK THERE IS ABSOLUTLY NO COMPARISON.
IF YOU ARE SERIOUSLY INTERESTED, FLY OVER AND SEE HOW IT RUNS, IF YOU ARE DISSAPOINTED I WILL REFUND YOUR EXPENSES.
Excuse me while I scrape my bottom lip up off my desk. THIS THING IS THE PUNISHER! Holy crap man. The great thing is I love NZ road laws. You can legaly drive a monster like this on the roads. OMG.
GL with the sale. You deserve every cent of this in return.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
