Hey Guys,
I have a 92 N1 GTR and was thinking on popping in a GREX oil cooler kit. However I have been reading that the N1's came with an upgraded oil cooler.
Can anyone confirm this? Where is it located?
I want to do a bit of track work, and was wondering if it's necessary to to upgrade to the GREX kit?
Cheers
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/
Have a look around the radiator, my guess is that it would be around there
Give it a bit of stick down old pac one day soon and keep an eye on the temps - that should give you an indication :D As a reference, my old setup with no cooler would hit 130degrees with ease on old pac doing the uphill section
I am BUSTING to have a look at your new car mate - Coming to any club events soon?
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4121498
Thanks Steve,
I'm busting to get to an event :-)
Hopefully the upcoming cruise, if all goes well.
I'll have a look around the radiator tonight when i get home.
I haven't given it too much so far (have hardly driven it!) but I'm yet to see oil temps over 90 (on the stock guage).
I was going to do the cooler this weekend and take it from there.
To be honest, I'm getting the GREX kit from a mate for $300 so may just do it anyway. Will give me even more track days in 40degree Wakie summer heat.
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4121527
Thanks guys.
I may have missed out, or they could have only came on the second series of R32 N1's (V-spec's) cause I can't find anything.
Unless I'm completely blind (which is possible).
I've checked infront of the rad. and in the front bar on both sides in front of the wheel wells and nothing that i can see.
Ryan, if I find a cooler already on mine, no drama's.
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4121854
I'm not sure where the standard n1 32 cooler sits, the only way to confirm is to look for 2 oil lines coming from a sandwich plate under the oil filter. I'll try and dig the pics out of fast - either post or pm me your vin and i will look it up
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4122505
Is it this exact oil cooler that nissan want a crazy amount of dollars for or is it the later model N1 coolers?
I think they want crazy amounts for both mate.
Hopefully I've just missed it and there is one on the car.
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4122914
thanks buddy,
Not to fussed if it isn't cause $300 for the GREX kit including filter relocator in virtually brand new cond. aint that bad. It's just the hassle of fitting it :-)
A mate who's gone a big single on a 32 GTR bought the GREX kit which had a couple of thousand k's on it, but then decided to go brand new as it was pretty much the only second hand part on the engine build.
On a side note, he fired it up last week for the first time and put out a nice 430kw at the rears only.
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4123080
Thanks Duncan,
I'm going to take the front bar off this weekend and see what I can find. You'd imagine that something that size should be visible but I couldn't see anything.
I'll see how i go.
Don't take the bloody front bar off you goon! :) Have a look at the oil filter area and look for two hoses of 2-3cm diameter coming out from a sandwich plate (about 2-3cm thick) sitting between the oil filter and the block. If you find the hoses, follow them down the yellow brick road to nirvana.
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4124905
If you dont use your mates cooler set up may i purchase it :)
Nice power! PM Sent btw
$300 for that? ill give you $400 for it, today! Unless someone has already got in for it :P
you are one of a kind steve-o.... nice way to bogart the purchase there. nono.gif
https://www.sau.com.au/forums/topic/235355-n1-oil-cooler/#findComment-4125033
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
