Hello all
Wondering what flows better.
Aftermarket airfilter of high-flowing variety in standard RB26 airbox
or
Twin pod filters.
I have a pod on the supra, but it is relocated into the wheel well away from hot engine air.
I would like to retain the stock airbox for this function but if it's design is restrictive I will give it the arse.
thanks
https://www.sau.com.au/forums/topic/235362-rb26-airbox-vs-pod-filters/
Just upgrade the panel filter to a high flowing one.
Pods are good too but best to be sheilded off with an aftermarket air box or a custom made one, which a lot of ppl have made themself.
I was very interested in this discussion a while ago so i did both; bought the apexi pod kit and an apexi panel filter replacment.
The box was good but felt a little restricted compared to the free pods, power came on in a nice smooth surge rather than a violent shake.
Dyno run with the panel filter was done at 235awkw
another dyno will be done tomorrow (10-sep) which will see of any power gains from pods.
Cheers Johnny, sounds interesting
What modifications are you running?
I'm looking at just doing airfilter + HKS style dumps (i know, not great, but better than stock :blink: ), eBay front pipes, "high flow" cat, (already got cat back)
then maybe a haltech e11v2, boost it up to 12-13psi...
230rwkw+ would be nice! :D
Cheers mate
Rememeber to take into account that the dyno run is done with the bonnet up. That allows the pods to inhale cold air from above the engine. Unlike when the bonnet is down, and they inhale hot air from inside the engine bay (in the absence of a good divider panel).
Your testing was fundamentally flawed.
RyleyMA61 - you should read this before taking advice. (page 2 onwards, his testing was not even or comparable)
http://www.skylinesaustralia.com/forums/Po...ps-t228302.html
alright thanks everyone, having a read of that thread now.
as for ebay dumps- not even better than stock?? what size and how restrictive are the stock ones? what about ebay front pipes? what are they like??
thanks all, appreciated :P
even so, when the car is travelling on the roads at 60,70,80km+ etc the whole engine bay is full of cold air, a pod would never suck in hot air whilst driving as the heat never stays around.
The only issue with hot air would be when idling as the hot air is not pushed out by any flowing air from movement.
Also, putting down the bonnet would be more off from real world results, as the dyno fan can only do so much which is usually aimed at the FMIC/Radiator
^^ quite the contrary.
Having watched my temp sensor with keen interest in peak hour traffic i get upto ~ 50-55 degrees.
Now, once driving along @ 70km/h, it doesnt drop off anywhere near as fast as you'd expect :D
Its a good 1-2mins before it drops from the peak value, and then another 4-6 before it gets back to a normal level
If you stop, then it goes up once again.
So even in stop/go it shows effects.
Also having pushed the car for 10-15mins, slowing down also see's the temp go up, even while push it it does rise.
I found it all quite interesting, pity i cant fit an airbox in :(
But CAI will be looked into eventually
ill have to give it a shot one day. Ive got a temp sensor multi-meter but no way to read the numbers. Unless someone is willing to sit in the engine bay :D
edit;
Although, when thinking about it. The temp-prob may have heated up from the idling engine, and will take a while to cool it self down.
Whereas in an airpod, it is sucking in air at high speeds, whereby the velocity is too quick for the surrounding heat to transfer any energy to the air.
Same can be said as to why insulating the cross over pipe doesnt affect the air temp's as there is not enough time for the heat to transfer through the pipe to the air rushing into the manifold.
yeah all info is good info, thanks guys
my understanding of engine bay heat (with use of undertray that covers front half of bay) from an engineering perspective
air builds up in the front of the engine bay and therefore pressure, this creating a negative pressure region at the lower/back on the engine and air is "sucked" out that way.
that said there were noticible gains from relocating my pod filter in the supra from the engine bay to the wheel arch....
so yeah, any advice people have is welcome
RESULTS:
Apexi panel filter with lower half of boxed removed: 235awkw
Apexi power intake pod filters: 255awkw
-So a nice 20kw gain
So we can see that the airbox, although able to support big power numbers will provide a restriction of air volume and velocity.
Now in real world, driven in stop-start traffic conditions the extra airflow will probably be negated by the increased underbonnet temperatures but driven in low traffic conditions where roadspeed is a constant above say 50km/h the results are an increase in power and response.
I will make a new thread tonight with the dyno run sheet for anyone whos interested to read. Next stage will be monitoring of intake temperatures via vspec and power fc sensors in different conditions and addition of a carbon partition to see if i can get the best of both worlds.
-John
RESULTS:
-John
Did you remove the side blockage to the airbox also?
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
