so tonight i had the unpleasant experience of someone attempting to steal my car, and it's raising a few questions about car security.
i'm going to install an alarm system on thursday into the car, and i've spent the better part of my afternoon cleaning the garage to get it in there with the other car. But i'm also looking to install a killswitch, and one idea i did have was to get a button installed inside the cigarette lighter unit (have never used a cigarette lighter in the car in my life) im just wondering if anyone would have the patience to give me a run down on how i would achieve such a thing, or point me in the direction to do it.
https://www.sau.com.au/forums/topic/235423-killswitch/
If i were you I would now look for another spot. You just told everybody where that one is.
https://www.sau.com.au/forums/topic/235423-killswitch/#findComment-4123391
+1 for that...
idea is that only YOU know where it is... lol i have 1 installed in my car... hidden ofcourse... but instead of using a switch i used a coded magnet. sensor behind the dash (cannot see) which switches some relays which is wired into the car...
https://www.sau.com.au/forums/topic/235423-killswitch/#findComment-4124148
Remember with kill switches, it should not be wired in somewhere easy to find (i mean the location of the wire-cut, as well as the switch), such as under the steering wheel. If you drop that panel and see two wires, its easy to bypass your kill switch. You want to spend some serious time pulling apart your car, and find a loom which is usually very hard to get to, and join your switch in there.
https://www.sau.com.au/forums/topic/235423-killswitch/#findComment-4127936
it does not matter where you place that kill switch, as long as an experience car theif can get behind your ignition wiring loom, he can steal/overide it.
What i would recommend, do a switch for your fuel pump.
also if you want a switch for your ignition (similar to what alarm system do) cut the ignition power or ignition start wire and take a section out and re run it so it is not easy to find (ie easy to hot wire) , then run a relay with a switch for it.
https://www.sau.com.au/forums/topic/235423-killswitch/#findComment-4130934
there are so many ways that you could do it... just make sure that you do your research before hand ie. wiring diagrams, advice from other SAU'ers, etc and be patient... dont get excited thinking that ur gonna cut all these wires and its just gonna work. plan what you want to do, get all ur parts (switches, cable, relays, etc) then give urself a free day and do it... there is no need to rush it cuz if u do, ur heaps more likely to fu*k it up...
https://www.sau.com.au/forums/topic/235423-killswitch/#findComment-4131333
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
