hey guys
got an r33 gtst with stock looking rims, except the rears are 7.5" wide, fronts 6.5" (as pointed out by the tyre shop)
i've getting some bad understeer on the track. will this drastically change if i upgrade to wider front (and rear) wheels? or am i better off putting $1000 into swaybars / subframe alignment / camber etc?
cheers
https://www.sau.com.au/forums/topic/235428-wheel-width/
I would first look at getting the swaybars as you can then change the characteristics of the chassis and they will make the biggest difference as they will also reduce body roll.
When money permits I would go as wide as you can with wheels ie. 8.5 front, 9.5 rear.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4123011
id be looking around for some cheap 2nd hand wheels, maybe a few hundred $$ worth, go at least 16" diameter and something up around at least 8". when i say cheap i dont mean tempe specials, i mean good lightish brand name wheels, just cheap in price (whether it be due to looks, gutter rash etc). chuck some decent wide tyres on them and upgrade the sway bars.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4123067
i was actually wondering if anyone could say if and why the stock rims are bad for track use
stock rims are thin, u cant fit as large tyres on them, its basically that simple.
for track use u have to remember the tyres are being put under higher force, so if u put wide tyres on thin wheels, ull have the tyres flopping around all over the place as there is less strength holding the sidewalls upright. if u have a wider rim and put a same size tyre on, the walls will be sit nice and vertical or slightly pulled in which keeps the sidewalls more rigid which obviously transfers to more responsive steering.
although then there is the issue of unsprung weight, but tbh i think thats less of an issue.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4125034
heres a question
just say you are running a 235/45/17 on a 9" and a 7.5" rim would you notice a difference between the two?
yes, big difference. the 9" will have more rigid sidewalls and movement of the tread will transfer more directly into the wheel and in turn the steering. this can mean u get tracking where the wheel follows the road more, not great for highway driving but great for steering response.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4125042
i guess the theory of wider wheels / tyres is pretty simple. but can anyone quantify the difference (perhaps when they have upgraded to wider wheels)?
as in, have people felt there was a WORLD of difference in turn in ability when they have gone from 215 to 245 front tyres (for example)?
just like this thread (except this one is all about swaybars);
http://www.skylinesaustralia.com/forums/In...rs-t235329.html
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4125151
yeah you're right
i guess if i think about it logically, its going to be $1600 - $2000 for some rims and OK rubber
full swaybars are going to be $500ish
so the wheels option is going to cost about 4 times more than swaybars. will it give 4 times the benefits? i doubt it... (but could be wrong)
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4126591
toyo t1r's
however they are 225's up front which are a little too wide. i could take them off and put 205's to reduce sidewall flex, but i'd loose contact area.
would i notice a huge improvement by downsizing tyres, or would it be better off investing the $400+ on tyres into swaybars? argh....
:P
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4127301
swaybars are ur best bet, but as i said u dont have to spend big $$ on rims, just buy smart. something like this:
http://hardtuned.net/forums/index.php?showtopic=333667
there are much better examples around obviously, and if need be u can just buy 2 pairs if they are dirt cheap.
quality rims, decent width, and if u buy well u could probably get away with a similar set for less than $400.
but yeh, go the sway bars first.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4127374
Tyre profile would be far more noticeable than changing tyre size on your rim. That said, swaybars will make a significant difference. By themselves, they will improve the cornering ability of your car noticeably, but once you've stiffened up the roll rate through tightening adjustable swaybars, you can back off your dampers and enjoy the benefits of better roadholding mid-corner as your shocks can now do a better job of absorbing bumps, rather than being set hard to stop body-roll.
Swaybars are my suggestion.
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4127421
hmm is it legal to have mismatched rims on the street?
there are no ADR's requiring the wheels to match front and rear.
saying that u are only allowed to go 1" wider and increase the track by 26mm (13mm each side), so pretty sure legally your limit is a 18x7.5 +27. those rims i showed u are legal besides being 1/2" over width, but no cop should be able to tell what width they are. in other words if u get defected for them, u were gonna get defected for them regardless of whether they were legal or not as the officer cannot tell what size they are from the outside (unless the size is stamped on the outside of the disk).
https://www.sau.com.au/forums/topic/235428-wheel-width/#findComment-4127700
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
