Information I was given a few years ago.
to decrease understeer:
Front needs - higher tyre pressure, taller sidewall (higher profile), more negative camber, lighter swaybar, softer springs, less weight forward.
there are no ADR's requiring the wheels to match front and rear.
saying that u are only allowed to go 1" wider and increase the track by 26mm (13mm each side), so pretty sure legally your limit is a 18x7.5 +27. those rims i showed u are legal besides being 1/2" over width, but no cop should be able to tell what width they are. in other words if u get defected for them, u were gonna get defected for them regardless of whether they were legal or not as the officer cannot tell what size they are from the outside (unless the size is stamped on the outside of the disk).
as long as you keep your stockies you should be right if you get defected. just slap em back on till you get it cleared then put the wider rims back on. or do as someone sugested and buy yourself a GTR tyre placard from nissan (they have 8" or 9" as standard) to avoid complications :)
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
