hey ppls
i had a small incident at the carpark the other day. the parking spot is realllly tight i crashed into a parked vehicle as i was trying to park. the front bodykit was slightly damaged (see pic). i got rid of most of the scratch marks but im having trouble fixing the body kit. it seems a lil deformed and two bolts seemed to hav been ripped out. im having trouble pushing the bodykit back into place. any ideas how i can fix it?
https://www.sau.com.au/forums/topic/235445-help-plz-front-bodykit-damage/
to properly fix that i think you have to take the bumper off or just unbolt that side and fiddle with it. its ripped of the plastic that the screws go through on the bar and is probably still there bolted into the fender/chassis. i bent mine when i hit the gutter hard but i didnt rip it off like yours
There will be two screws and a plastic locator holding the side of the bumper on.
Pull back the stone guard from the wheel arch so you can locate the screws, remove the two screws, re position body kit tighten screws. If the body kit is heavily damaged around the screw holes you might need to use a couple of washers to hold it on.
I found this pic on google and attached where the screws and the locator are.
Hope this helps. Sorry about the poor quality pic.
Doc1.doc
