For Sale: RB26DETT Engine
Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
